Saleen S7 TT Posted March 14, 2010 Share Posted March 14, 2010 I get so confused with all the options there are, I know the sticky is one option. But I remember seeing an aux-in that doesn't require a black CD which would be nice. How hard is it to install something like this? I want one that will be easy to use and under $100. If I have a friend that wants to use an iPod, they can just use the aux also right? I really wish these cars had an aftermarket headunit option that isn't over $200 (least I've seen is $750!), not including the headunit. Thanks for any input! Link to comment Share on other sites More sharing options...
RedFloyd Posted March 16, 2010 Share Posted March 16, 2010 I would say the Leptronix aux in, but I'm a little biased! Link to comment Share on other sites More sharing options...
wcbjr Posted March 17, 2010 Share Posted March 17, 2010 http://www.avojdm.com/product_info.php?manufacturers_id=11&products_id=102&osCsid=d6f7c89c6f739bddc12d952521630a7e http://www.crutchfield.com/p_1303200UB/Pioneer-DEH-3200UB.html?search=3200&ssi=0 http://img.photobucket.com/albums/v334/wcbjr/deck.jpg Ok, so it's not under $200 total. And yes, the clock wasn't set yet. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted March 17, 2010 Share Posted March 17, 2010 I swapped in a 2008 Radio for about $200, sold my OEM HU for $120, and wired in a radio shack cord per the sticky. Aux in works perfect. On the search for a new DD... Link to comment Share on other sites More sharing options...
BravoZero Posted March 18, 2010 Share Posted March 18, 2010 Is there a way you could wire BOTH head units to either a line out converter or an amp, so that you could use either head unit on the same speakers? If so, I may have an idea... Link to comment Share on other sites More sharing options...
SVXdc Posted March 19, 2010 Share Posted March 19, 2010 The easiest way would be to connect one pair of speaker outputs (fronts or rears) from the OEM HU into a LOC, and connect that into an aux input on the aftermarket HU. To connect both HUs to an amp, you would need to rig up some kind of switch. Link to comment Share on other sites More sharing options...
BravoZero Posted March 19, 2010 Share Posted March 19, 2010 A toggle switch right? So it is indeed possible? Link to comment Share on other sites More sharing options...
SVXdc Posted March 19, 2010 Share Posted March 19, 2010 Yes, but you may need to take extra precautions to avoid an annoying (and possibly speaker-damaging) *pop* when you switch inputs. Link to comment Share on other sites More sharing options...
BravoZero Posted March 19, 2010 Share Posted March 19, 2010 Im sure that has a work-around. Link to comment Share on other sites More sharing options...
