Drew888 Posted March 16, 2010 Share Posted March 16, 2010 Aaaaaaahhhh...I want one sooo bad but running low on the fundage. [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
Strizzy Posted March 16, 2010 Author Share Posted March 16, 2010 Do you need a new clutch anytime soon? If so, that will be the time to get one installed. My installer only charged $50 extra to install the LSD. You should be able to find a 05+ STi front LSD for around $250, or from what I have read, a new one from the dealer should be around $500. The results are well worth the expense. I am glad I sucked it up and got it done with my new clutch. Now I just wonder how difficult it would be to put in a STi DCCD in the spec.B My bad luck build Link to comment Share on other sites More sharing options...
Guest Posted March 16, 2010 Share Posted March 16, 2010 Now I just wonder how difficult it would be to put in a STi DCCD in the spec.B Difficult. You need the center diff and the tail housing. The main housing does not have hole for DCCD wires, not sure if it could be drilled. Instead I went from 08 SpecB tranny (w/front LSD) to 08 STI tranny (w/tall 5-6 gears). Easier and cheaper. I'll install the SpecB tranny in my second "less hardcore" LGT. Link to comment Share on other sites More sharing options...
Guest Posted March 16, 2010 Share Posted March 16, 2010 I got my car back today and all I can say is WOW!! It feels like a completely different car, and in a really good way. The front end feels amazing through turns and no more power-on understeer!!! Just give it some gas, point, give more gas and you're flying through corners like it's nobody's business. The steering feels tighter; not in a sense that it is difficult to turn, but more that the car feels better planted on the road. Out of 10 points, I rate the addition of a front LSD about a 12. Unfortunately, I have to drive like a civilized person so my clutch properly breaks in before putting the LSD through a real test... Told you so.... Link to comment Share on other sites More sharing options...
UniqueTII Posted March 16, 2010 Share Posted March 16, 2010 I can't wait to get my car back from DS1, although I'll be pulling the engine as soon as I get back to Iowa with it. Link to comment Share on other sites More sharing options...
Strizzy Posted March 20, 2010 Author Share Posted March 20, 2010 I can't wait to get my car back from DS1, although I'll be pulling the engine as soon as I get back to Iowa with it. Did you get your LSD installed yet? What do you think? My bad luck build Link to comment Share on other sites More sharing options...
UniqueTII Posted March 20, 2010 Share Posted March 20, 2010 I'll be picking my car up next weekend. Dylan has to track down a seal for my trans and rebuild my friend's WRX trans before we pick them up. Link to comment Share on other sites More sharing options...
Strizzy Posted March 30, 2010 Author Share Posted March 30, 2010 Get your car back yet? My bad luck build Link to comment Share on other sites More sharing options...
UniqueTII Posted March 30, 2010 Share Posted March 30, 2010 Yep, I got it back on Saturday (I replied to the other front LSD thread but forgot this one). I am thoroughly impressed with the diff and how the car pulls out of corners. Now I just need to get the suspension dialed in so it goes into corners equally well. Link to comment Share on other sites More sharing options...
