blankie55 Posted March 8, 2010 Share Posted March 8, 2010 I have a 95 legacy, I was putting a new timing belt on and everything lined up and looked good. when i tried to start it doesn't turn over and smoke comes out the air filter. Any suggestions? Link to comment Share on other sites More sharing options...
Bdubs Posted March 8, 2010 Share Posted March 8, 2010 Used the wrong marks on the pulleys? Don't use the arrows, those determine TDC of a piston. Hash marks on the outer rings are what you should be using to line the belt properly. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted March 8, 2010 Share Posted March 8, 2010 What engine is in this car? Is it the 2.2 or the 2.5? Not that it matters, both engines were pretty much the same in terms of timing belt changes, and both engines of that year were interference engines. When you say it doesn't turn over, do you mean the engine won't rotate at all, or that it won't fire and just keeps cranking? Either way my guess would be the timing is off. Link to comment Share on other sites More sharing options...
blankie55 Posted March 9, 2010 Author Share Posted March 9, 2010 It was the belt I had the crank lined up wrong! I got it running now. Link to comment Share on other sites More sharing options...
