rB5 Posted February 28, 2010 Share Posted February 28, 2010 Tried searching for this info. but didn't find anything. Exactly what are the differences between the 3rd (BH) and 4th gen. (BP) Outback suspension? Is it just the ride height (length of struts) or are there other major differences in the geometry/design of the components? What i'm trying to get at here is the compatibility of strut assemblies between the two. How different are they really? I've seen speculation about adapting BH suspension but it sounded kind of sketchy and nobody had definitive proof that it works... Thanks! -Branden Link to comment Share on other sites More sharing options...
Beanboy Posted March 1, 2010 Share Posted March 1, 2010 Completely different suspension in back. In front, definitely not a 100% fit, not sure if impossible or as you mentioned just issues with length/bolt mounting locations/top hats blahblah. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
Guest Posted March 1, 2010 Share Posted March 1, 2010 ^ Wrong. 3rd gen. Legacy/Outback has multilink rear suspension just like the 4th. At least in case of the Legacy lateral links are interchangeable, and likely shocks as well. It's the front, while both generations have strut suspension, the struts are not interchangeable. Link to comment Share on other sites More sharing options...
Beanboy Posted March 1, 2010 Share Posted March 1, 2010 But I'm from the Athens of Amer--oh my, you're from the Athens of America...and have part number access. Hmpt. I give up with Subaru suspension,the whole interchange/slight change between models has my old man brain too confused to offer advice. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
pachilla Posted March 3, 2010 Share Posted March 3, 2010 the springs/struts of the rear suspension is interchangeable betwen 3rd & 4th Gen legacy. The front springs/struts from 3rd gen will raise 4th gen legacy nose by about 2 inches. Link to comment Share on other sites More sharing options...
LIMITED Posted March 3, 2010 Share Posted March 3, 2010 sO if we put 4th Gen front spring/struts on a BE(3rd Gen.) it will drop by 2". Is this possible? Do the parts work without modification?Just curious, since BE options are very limited. Link to comment Share on other sites More sharing options...
rB5 Posted March 3, 2010 Author Share Posted March 3, 2010 the springs/struts of the rear suspension is interchangeable betwen 3rd & 4th Gen legacy. The front springs/struts from 3rd gen will raise 4th gen legacy nose by about 2 inches. The difference in front ride height is due to different strut mounting positions, not an actual change in strut length or stroke, correct? Link to comment Share on other sites More sharing options...
