d1000rr Posted February 25, 2010 Share Posted February 25, 2010 I've done a bunch of searching but can't come up with any solid answers so I thought I'd ask instead From what I can gather, the rims size is 5x100 (unsure of the stock offset). Does anyone have an idea of how aggressive we can go? ex. 17x9 et 32 - will that fit or stick out way to much? EDIT: As for bulb sizes: Headlights - H4 (1993-1997 models) Headlights - 9007 (1998-1999 models) Foglights - H3 Gauge cluster - 194 and 74 HVAC - Neo 3mm Dome Light/Map Light - DE3175 Someone correct me if I'm wrong. Thanks Link to comment Share on other sites More sharing options...
subikid90 Posted February 25, 2010 Share Posted February 25, 2010 my headlights are 9007 and fogs are H3, otherwise the rest seem right -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
d1000rr Posted February 25, 2010 Author Share Posted February 25, 2010 Are the headlight bulbs the same on the wagons and sedan? So H3 is the fogs... Thanks Link to comment Share on other sites More sharing options...
WESTcoast Posted February 25, 2010 Share Posted February 25, 2010 lgts have the same bulbs 9007 and h3 for the fogs and i think 1158 for the bulbs (somthing along those lines lgt stock snowflakes are 5x100 with a +58 offsett (somewhere in the 50's dont remeber) I think +48 is flush for us, but check up on the member's ride thread over in sl-i.net or any wrx site as the 02-05 wrx share the same offset with thier stock rims. Find someone's rims you like and ask for thier offset if the didnt already give it out there Link to comment Share on other sites More sharing options...
Blaeven Posted February 26, 2010 Share Posted February 26, 2010 +55 is stock subaru offset... i think the only subaru wheels that aren't +55 are some Sti wheels which are +53 i think... subaru 17s are 17x7... and 18s are 18x7 i'm pretty sure... if you have money to pump your guards you can potentially go up to a +38 offset... but anything lower than this is getting way too crazy... best is between +48 and +45... and even then, if your car is lowered, you will probably scrub out... if not on the guard then on the struts (depending how wide the wheels/tyres are) as far as width goes, i wouldn't go past 8 or maybe 8.5 at a stretch (unless you put undersized tyres on them, which isn't a look that suits the subies IMO) this is all from my experience and from what i've gathered from other people... don't take this as gospel or anything... oh, and the JDM projectors are H1 and the AUDM box headlights (the normal ones) use a dual filament (high/low) H4 bulb... this is for the ones that are separate from the indicators... i can't say what the US spec combined headlight/indicators use... Link to comment Share on other sites More sharing options...
WESTcoast Posted February 26, 2010 Share Posted February 26, 2010 blaveven hahaha i was trying soo hard to remeber the stock offset hahaha, my friend has nice set of volks and they are +48 and nicely flush with his wrx. Link to comment Share on other sites More sharing options...
Blaeven Posted February 26, 2010 Share Posted February 26, 2010 BTW, I run 225/45R17 (Bridgestone RE001 Potenzas - great tyres) on my JDM RS-B 17x7 +55 rims and they scrubbed out on the inner guard (on the engine side of the wheel) when lowered on my coilovers... Though if I had different wheels, running 53 or 48 offset for example, this potentially wouldn't have been an issue... Edit: WESTcoast; don't forget that wrx guards are a fair bit more pumped than ours... I've seen rexies with +25 wheels... (they stuck out like a mofo) there is no way they would fit on a gen2 unless it had a widebody kit or somethig crazy... Link to comment Share on other sites More sharing options...
d1000rr Posted February 26, 2010 Author Share Posted February 26, 2010 lgts have the same bulbs 9007 and h3 for the fogs and i think 1158 for the bulbs (somthing along those lines Awesome thanks for clarifying. I think +48 is flush for us, but check up on the member's ride thread over in sl-i.net or any wrx site as the 02-05 wrx share the same offset with thier stock rims. Find someone's rims you like and ask for thier offset if the didnt already give it out there +55 is stock subaru offset... i think the only subaru wheels that aren't +55 are some Sti wheels which are +53 i think... subaru 17s are 17x7... and 18s are 18x7 i'm pretty sure... if you have money to pump your guards you can potentially go up to a +38 offset... but anything lower than this is getting way too crazy... best is between +48 and +45... and even then, if your car is lowered, you will probably scrub out... if not on the guard then on the struts (depending how wide the wheels/tyres are) as far as width goes, i wouldn't go past 8 or maybe 8.5 at a stretch (unless you put undersized tyres on them, which isn't a look that suits the subies IMO) this is all from my experience and from what i've gathered from other people... don't take this as gospel or anything... So let me get this straight... we CAN run the same width and offset as 02-05 wrx's or do you mean the stock offsets are just the same? A buddy of mine has a bug eye wrx and I'm pretty sure he's running 18x9.5 et38's (rota grids) and he's pretty flush with rolled fenders... I kinda wanna get something aggressive with some sexy concaveness but I also don't want to look stupid cause it pokes to much... and i'm not into the stretched tire look either. Thanks for your help guys. Link to comment Share on other sites More sharing options...
98LGTLover Posted February 26, 2010 Share Posted February 26, 2010 Second Gen and Third Gen LGT's have the same stock 16" wheels 5X100 that take 205/55/R16 Tires. Link to comment Share on other sites More sharing options...
d1000rr Posted February 26, 2010 Author Share Posted February 26, 2010 Does anyone on here have 38et wheels on their 2nd gen? Link to comment Share on other sites More sharing options...
d1000rr Posted March 5, 2010 Author Share Posted March 5, 2010 Anyone? I'm close to buying a set of 17x9 et30 Link to comment Share on other sites More sharing options...
Blaeven Posted March 5, 2010 Share Posted March 5, 2010 omg... on a gen2?? are you crazy? welcome to scrub city Link to comment Share on other sites More sharing options...
d1000rr Posted March 5, 2010 Author Share Posted March 5, 2010 I wish I could test fit a set... I wonder if I can get away with it if I pull and roll the fenders...? Link to comment Share on other sites More sharing options...
Benders Posted March 5, 2010 Share Posted March 5, 2010 Second gen USDM Legacy one piece headlights (indicator and headlight in one piece) use a dual filament H4 bulb like the 2 piece ones do. Just for future reference. Lol -Ben Link to comment Share on other sites More sharing options...
d1000rr Posted March 5, 2010 Author Share Posted March 5, 2010 Second gen USDM Legacy one piece headlights (indicator and headlight in one piece) use a dual filament H4 bulb like the 2 piece ones do. Just for future reference. Lol -Ben I'm getting a lot of mixed information... I guess I can get off my ass and check for myself lol Why are people telling me 9007 if it's H4? I have the one piece headlight. EDIT: They are INFACT H4 headlight bulbs. Thanks Link to comment Share on other sites More sharing options...
Benders Posted March 6, 2010 Share Posted March 6, 2010 Because if I'm not mistaken (which I may be) 9007 and H4 are interchangeable. Which would be the reason for some saying H4 and some saying 9007. Correct me if I'm wrong. -Ben Link to comment Share on other sites More sharing options...
d1000rr Posted March 6, 2010 Author Share Posted March 6, 2010 Because if I'm not mistaken (which I may be) 9007 and H4 are interchangeable. Which would be the reason for some saying H4 and some saying 9007. Correct me if I'm wrong. -Ben Incorrect. H4/HB2/9003 are the same interchangeable bulbs. 9007 is completely different. H4 http://i238.photobucket.com/albums/ff181/melysaflower321/H1_and_H3_Bulbs.jpg 9007 http://lib.store.yahoo.net/lib/mustangtuning/luminics-9007-2s.jpg Link to comment Share on other sites More sharing options...
Benders Posted March 7, 2010 Share Posted March 7, 2010 Ah, yes you are correct. I was thinking of 9003 when I said they are interchangeable. That was my fault. good looking out. -Ben Link to comment Share on other sites More sharing options...
grovlet Posted March 7, 2010 Share Posted March 7, 2010 According to Sylvania Auto Lighting Guide they are 9007s... and I've replaced them with 9007s... So unless you've swapped headlights they are 9007s. Link to comment Share on other sites More sharing options...
d1000rr Posted March 7, 2010 Author Share Posted March 7, 2010 That's weird... I took the bulb out and actually looked at it yesterday and it was infact an H4 bulb. I did this while using the 3M Headlight Restore Kit. I have a Wagon and it's a 1 piece light... is yours 2 piece? Link to comment Share on other sites More sharing options...
Benders Posted March 8, 2010 Share Posted March 8, 2010 I have a 97 sedan with one piece headlights and I removed my bulbs and they are H4 as well. A 9007 won't fit in my headlight, nor plug into the headlight plug. Maybe in 98 Subaru changed bulb type on the Legacy?? Can you get a few pics of your headlights front and back for us so maybe we can figure it out? This is very interesting...... -Ben Link to comment Share on other sites More sharing options...
grovlet Posted March 8, 2010 Share Posted March 8, 2010 I have a 97 sedan with one piece headlights and I removed my bulbs and they are H4 as well. A 9007 won't fit in my headlight, nor plug into the headlight plug. Maybe in 98 Subaru changed bulb type on the Legacy?? Can you get a few pics of your headlights front and back for us so maybe we can figure it out? This is very interesting...... -Ben Looks like in 98 they changed the bulb type... 1993 to 1997 are all 9003, while 1998 and 1999s are 9007s... Sorry about that seeing as all the headlights appear the same I assumed the bulbs were too.... Link to comment Share on other sites More sharing options...
Giro Disc Posted March 9, 2010 Share Posted March 9, 2010 I had 18x8.5 +32 on my Lego for a bit. Rolled fenders so you can see from the pics you could easily tuck a 17x9 with a stretched tire. http://i186.photobucket.com/albums/x223/badwagon/Lego14.jpg http://i186.photobucket.com/albums/x223/badwagon/Lego12.jpg Got 18x9.5 +15s on now with a little help from a few 90 Honda Accord fenders lol http://i186.photobucket.com/albums/x223/badwagon/lego35.jpg Johann @ Girodisc Link to comment Share on other sites More sharing options...
Blake M Posted March 9, 2010 Share Posted March 9, 2010 http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/AutoLRG-Results.htm here is the sylvania, 97 legacy light size chart Link to comment Share on other sites More sharing options...
d1000rr Posted March 9, 2010 Author Share Posted March 9, 2010 Looks like in 98 they changed the bulb type... 1993 to 1997 are all 9003, while 1998 and 1999s are 9007s... Sorry about that seeing as all the headlights appear the same I assumed the bulbs were too.... No worries... atleast we all know now... I had 18x8.5 +32 on my Lego for a bit. Rolled fenders so you can see from the pics you could easily tuck a 17x9 with a stretched tire. http://i186.photobucket.com/albums/x223/badwagon/Lego14.jpg http://i186.photobucket.com/albums/x223/badwagon/Lego12.jpg Got 18x9.5 +15s on now with a little help from a few 90 Honda Accord fenders lol http://i186.photobucket.com/albums/x223/badwagon/lego35.jpg Johann @ Girodisc Amazing... this is exactly what I wanted to hear and see. I think I'm gonna do 17x9 et30 and stretch the tire a tiny bit... Thanks. ps. the new wheels are DOPE! Link to comment Share on other sites More sharing options...
