98JDMLegacyLimited Posted February 25, 2010 Share Posted February 25, 2010 I have a whine which is dependant on engine speed, I did wonder if it was the steering pump but it doesnt seem to change as you turn the wheel. It wont do it when in park or stopped only when driving under load. Any idea? To be honest it sounds like a worn out brush on an electric motor running on the armature segments (for those of you who have had the brush collapse on their electric drill)) Link to comment Share on other sites More sharing options...
98quiksilvergt Posted February 25, 2010 Share Posted February 25, 2010 Sounds like the alternator. Link to comment Share on other sites More sharing options...
kaz98gt Posted February 25, 2010 Share Posted February 25, 2010 have a buddy rev the engine while you hold a stethescope or end of a screwdriver to different parts where you think the noise may be coming from. then you can narrow things down, but the way you described it, sounds like the alternator. triple check though haha Link to comment Share on other sites More sharing options...
98JDMLegacyLimited Posted February 26, 2010 Author Share Posted February 26, 2010 has a brand new alternator so it is not that, I think it is the tranny but I cant seem to put my thumb on it. and it only makes the noise when under a load and driving so I cant really test it like you mentioned. it makes the noise only when I accelerate with the car in drive (tried all gears except reverse same result) when the car is in park or nuetral and I rev it it does not make the noise, also car is starting to shake or vibrate just a little more than normal when in gear and at a stop but runs smooth when driving minus that damn whinning/rubbing noise? Link to comment Share on other sites More sharing options...
malimx6 Posted December 24, 2013 Share Posted December 24, 2013 I have the same noise but i notice it only in winter. have you ever figured out what the issue was? thx Link to comment Share on other sites More sharing options...
Idaho subaru Posted December 24, 2013 Share Posted December 24, 2013 My '92 does the same thing, it will whine under load, go silent when you let off the gas, until the trans starts slowing you down, then it will whine again? I suspect it is front diff related, probably a bearing going out. Lots of posts about tranny noise. Most suggest replacing the entire front diff and trans as one unit from a junkyard. Seems like it might not be easy to seperate them, and seems pretty expensive to repair. Here are a couple links http://sl-i.net/FORUM/viewtopic.php?f=70&t=6367 http://legacygt.com/forums/showthread.php/no-r-r-front-diff-chilton-fsm-218094.html Have you checked the oil level? passenger side, way down low, short yellow dipstick. Some here have suggested a special type of gear oil also, can't remember the name, maybe they will chime in. Otherwise just 75/90w gear lube. Link to comment Share on other sites More sharing options...
spooln30 Posted December 24, 2013 Share Posted December 24, 2013 Why don't you just remove the alt belt and if the noise goes away then it either the alt or pump. If the noises still there try removing the AC compressor belt just to make sure. Is the noise speed dependent or just rpm? Can you post a vid of the engine ? Link to comment Share on other sites More sharing options...
Idaho subaru Posted December 24, 2013 Share Posted December 24, 2013 has a brand new alternator it only makes the noise when under a load and driving it makes the noise only when I accelerate with the car in drive (tried all gears except reverse same result) when the car is in park or nuetral and I rev it it does not make the noise It wont do it when in park or stopped only when driving under load Link to comment Share on other sites More sharing options...
