Razor Posted February 25, 2010 Author Share Posted February 25, 2010 I baught some RTV to seal that turbo to tmic connection. Subyshop, did you put the silicon ON the gasket then tighten it down ? Or did you just fill around the connection after it was torqued? also, smoke test didnt reveal anything but it isn't exactly pressurized. Next on the list. 1. tighen down connections and use RTV to seal suspected tmic joints 2. if that doesnt work, go back to stock bcs system and reload old tune. see if there are 'leaks' or not. does anyone remember for the stock bcs which port goes to the T, and which one goes to the air intake inlet ? Link to comment Share on other sites More sharing options...
dudeondacouch Posted February 25, 2010 Share Posted February 25, 2010 i don't know off hand, but if you go back to stock EBCS and can't figure it out, i can walk out to the garage and look. Link to comment Share on other sites More sharing options...
Razor Posted February 25, 2010 Author Share Posted February 25, 2010 Go take a walk plz Link to comment Share on other sites More sharing options...
SubyShop.com Posted February 26, 2010 Share Posted February 26, 2010 I baught some RTV to seal that turbo to tmic connection. Subyshop, did you put the silicon ON the gasket then tighten it down ? Or did you just fill around the connection after it was torqued? also, smoke test didnt reveal anything but it isn't exactly pressurized. Next on the list. 1. tighen down connections and use RTV to seal suspected tmic joints 2. if that doesnt work, go back to stock bcs system and reload old tune. see if there are 'leaks' or not. does anyone remember for the stock bcs which port goes to the T, and which one goes to the air intake inlet ? For the EBCS, make sure you look at which port is going where to double check. it sounds like you have it connected properly. Also, it might be worth having your tuner double check the map and make sure it isn't something simple like the WGDC table still calling for 0's in certain cells. Also it is worth trying to reset the ECU and flash the map again. The AP got touchy once with not properly overwriting certain tables. I put RTV on one side of the metal gasket (the intercooler side), and then carefully set the intercooler evenly on the gasket and bolted it down. It helps to have a friend hold the gasket while you ease the intercooler down. I let the car sit like that for a few hours and ran it easy while I dialed in the closed loop MAF values. -Franz Link to comment Share on other sites More sharing options...
dudeondacouch Posted February 26, 2010 Share Posted February 26, 2010 Go take a walk plz sorry... went to the market. the one on the end goes to the intake inlet the one closer to the wiring harness goes to the T-fitting Link to comment Share on other sites More sharing options...
NSFW Posted February 26, 2010 Share Posted February 26, 2010 IThis week I installed an AVO tmic and grimspeed ebcs with a custom emap tune. Since the installation of the tmic and grimmspeed ebcs, I have had this problem. It is entirely possible that your installation is just fine and the problem is the tune. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted February 26, 2010 Share Posted February 26, 2010 Other then not getting the boost to the WG actuator, just about any possible problem like a boost leak will result in less boost. Do the tests we said and get back to us. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Razor Posted February 26, 2010 Author Share Posted February 26, 2010 Just in limbo while I wait for a 0 WGDC map... not sure what a 'learning' view for the car is. Link to comment Share on other sites More sharing options...
SubyShop.com Posted February 26, 2010 Share Posted February 26, 2010 if you have a laptop.. http://www.romraider.com/forum/topic2772.html -Franz Link to comment Share on other sites More sharing options...
Razor Posted March 1, 2010 Author Share Posted March 1, 2010 Okay guys heres a log at 0& WGDC. Still hitting max boost, what do you thinks the problem? Next step is to start tuning with my old BCS. Do I have to replace that pill? or make it bigger? I was overboosting before with the stock vf40 pill ...razor vf52 0wgdc datalog 1.csv Link to comment Share on other sites More sharing options...
Spec B Posted March 1, 2010 Share Posted March 1, 2010 I would not go WOT again..you are knocking from 4800 to redline. I suspect this is because your maf is not scaled and you are running super lean (because of the overboost). Are you at sea level? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted March 1, 2010 Share Posted March 1, 2010 Okay guys heres a log at 0& WGDC. Still hitting max boost, what do you thinks the problem? Next step is to start tuning with my old BCS. Do I have to replace that pill? or make it bigger? I was overboosting before with the stock vf40 pill ... You are knocking, yes. But hey, your turbo creeps, there is likely nothing you can do about it, other then get a more restrictive exhaust or intake, or port the turbine housing. My buddies was hitting over 22 psi at 0% WGDC when it was like -20F outside! Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Legacy_GT_Pilot Posted March 2, 2010 Share Posted March 2, 2010 What DP are you using, and are you sure the wastegate flapper is fully opening? Do these VF52's really creep that much? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted March 2, 2010 Share Posted March 2, 2010 Always a good idea to check the flapper. Yes they can creep that bad: VF52 major boost creeeeeep!!!!!!!!............by LBGT Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Razor Posted March 6, 2010 Author Share Posted March 6, 2010 so im still creeping after a changed to my old BCS. also, what would it cost for someone to port the exhaust housing ? would this fix it ? or would an external WG actuator fix this problem? Also, whats an easy way to test that my actuator is acctually working ? Link to comment Share on other sites More sharing options...
NSFW Posted March 7, 2010 Share Posted March 7, 2010 Have you tried running a hose from the compressor nipple directly to the WG actuator? Link to comment Share on other sites More sharing options...
integroid Posted March 7, 2010 Share Posted March 7, 2010 so im still creeping after a changed to my old BCS. also, what would it cost for someone to port the exhaust housing ? would this fix it ? or would an external WG actuator fix this problem? Also, whats an easy way to test that my actuator is acctually working ? Just becareful when porting the WG port. If you make the hole too big, the flapper wont seal and you will never hit target boost. If you went with an EWG setup, you wont ever have to worry about your WG being the cause of your creep:) Link to comment Share on other sites More sharing options...
