Vwown3d Posted April 8, 2010 Author Share Posted April 8, 2010 Stupid question about the Camp2, can you still use aux inputs from other devices in back of the NAV thru the video port? For Example, I have an Iphone cable that I can show movies thru the nav aux input...will I have to disconnect that or will I be able run both somehow. You can but it will take some work. I had the same thing going and I got rid of the ipod movies for now. But there is a way to run both I just haven't had the time to wire it up. Link to comment Share on other sites More sharing options...
Sergio914 Posted August 5, 2010 Share Posted August 5, 2010 Can you provide a write up on how you actually disassembled the dash? I really don't feel like breaking anything haha Link to comment Share on other sites More sharing options...
tjbev21 Posted August 5, 2010 Share Posted August 5, 2010 Looks good man, I did the same thing buy flat black pastic paint. I love it. Btw do you have any extra 3m left? I would love to do my side trim Link to comment Share on other sites More sharing options...
Drew888 Posted August 6, 2010 Share Posted August 6, 2010 HKS Camp II update?! Hows it working for ya? [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
Drew888 Posted November 9, 2010 Share Posted November 9, 2010 Thought I'd update his thread since I just installed the HKS CAMP II also. First of all, get your self some good interior panel removal tools. It comes with like 6 pieces but I always end up only using the smallest piece. Second, if you are buying additional sensors you need the sensor kit (all are about $100ea) and the I/F Unit (another $100) to connect them to the main box. I bought the oil pressure and boost and will soon purchase the EGT. I ran all wires through the grommet just under the dogbone on the drivers side. If you poke a hanger through there you'll see it comes out just above the throttle and just behind the center console. I mounted the box just to the right of the instrument cluster. It will wedge tightly between the cluster and the metal frame to the right of it. It's a great spot you'll see. After that, I ran the OBD cable across to the main fuse panel and tapped the 'r. wiper/washer 15amp fuse' (you'll notice we don't have one...perfect). To use it in a Spec-B you simply tap the Info buton a second time. Done... [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
Mr. Sinister Posted November 10, 2010 Share Posted November 10, 2010 To use it in a Spec-B you simply tap the Info buton a second time. Done... Did you have to ground one of the wires that connects to the back of the NAV screen so it would work while the car was moving? Link to comment Share on other sites More sharing options...
DRoc7822 Posted November 10, 2010 Share Posted November 10, 2010 This is the exact same color scheme that Im going with in my car.... thing looks badass!! Link to comment Share on other sites More sharing options...
Drew888 Posted November 10, 2010 Share Posted November 10, 2010 Did you have to ground one of the wires that connects to the back of the NAV screen so it would work while the car was moving? Wow it's been 2 years... I believe so. I followed the instructions inthe huge Nav hacking thread. While in there last weekend I did notice the gray wire cut and hanging loose from behind the radio. [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
Mr. Sinister Posted November 10, 2010 Share Posted November 10, 2010 Wow it's been 2 years... I believe so. I followed the instructions inthe huge Nav hacking thread. While in there last weekend I did notice the gray wire cut and hanging loose from behind the radio. Cool. Just making sure. Thanks. Link to comment Share on other sites More sharing options...
