dr_sharp Posted February 17, 2010 Share Posted February 17, 2010 Thinking of getting the catted DP and UP from ERZ... it seems like this is everyone's favorite with the only other contender being invidia... How hard are these to install? These parts are moving into territory that I'm not familiar with. Thanks lol Link to comment Share on other sites More sharing options...
scoobydoobie Posted February 17, 2010 Share Posted February 17, 2010 DP is easy, UP a little more difficult and time consuming. But you have to have the DP off to get to the UP bolts, so it makes sense to do them at the same time. PBblaster, a breaker bar, and some beer should come in handy Link to comment Share on other sites More sharing options...
GTLEGACY007 Posted February 17, 2010 Share Posted February 17, 2010 Does ERZ make a UP for our cars? If so, where do i find one? Link to comment Share on other sites More sharing options...
dr_sharp Posted February 17, 2010 Author Share Posted February 17, 2010 They way I'm seeing it is really simple... just a few bolts at each end with some supporting mechanism in the middle, perhaps. I'm assuming that the difficult part is getting to the bolts and then getting in a position to apply the necessary torque... is that an accurate assessment? lol Link to comment Share on other sites More sharing options...
scoobydoobie Posted February 17, 2010 Share Posted February 17, 2010 They way I'm seeing it is really simple... just a few bolts at each end with some supporting mechanism in the middle, perhaps. I'm assuming that the difficult part is getting to the bolts and then getting in a position to apply the necessary torque... is that an accurate assessment? Pretty much. Some bolts will be really tight and not want to come off. If some are rusted out, be prepared to cut them off and replace them. Its a little tricky too getting the stock UP out. I dropped the manifold and twisted it out without jacking up the motor, but some people jack the motor up a tiny bit to help get the UP out a bit easier. Link to comment Share on other sites More sharing options...
dr_sharp Posted February 17, 2010 Author Share Posted February 17, 2010 Does ERZ make a UP for our cars? If so, where do i find one? I may have spoke too soon ... I had assumed they make UP as well.... but I'm not finding them anywhere either... lol Link to comment Share on other sites More sharing options...
gotsflat4love Posted February 17, 2010 Share Posted February 17, 2010 You can get an erz pipe for 02-07 Sti and itfits perfect. The debate is still out on flex to no flex up pipes. Dr. Sharp, there is no reason why you would need one. You have a catless uppipe stock. Save your money for something else. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted February 17, 2010 Share Posted February 17, 2010 Dr. Sharp...You have a catless uppipe stock. Save your money for something else. ^ what he said Link to comment Share on other sites More sharing options...
dr_sharp Posted February 17, 2010 Author Share Posted February 17, 2010 If the only advantage of getting aftermarket pipes is for removing cats, then why would anyone want a catted DP? Are the pipes significantly different length? Or is the DP much more of a restriction due to diameter? Thank you for the input guys, I appreciate it. Like I said, this is uncharted territory so I'm just trying to learn here. lol Link to comment Share on other sites More sharing options...
John M Posted February 17, 2010 Share Posted February 17, 2010 My ERZ UP with flex has been perfect for over 5 years. The cat in a catted DP is a high-flow variety so it's less restrictive than stock. I run one just for the fumes; I don't care if it leaves a little power on the table. Link to comment Share on other sites More sharing options...
JaeGT Posted February 17, 2010 Share Posted February 17, 2010 you might be misinterpreting 'catted vs cattless'. catted dp's or the more precise is 'high flow catted' dp. some states have emissions laws, so therefore a catted dp is a MUST to pass inspections. performance wise is not much difference. Link to comment Share on other sites More sharing options...
scoobydoobie Posted February 17, 2010 Share Posted February 17, 2010 Yep even a catted DP removes the two stock restrictive cats and replaces them with a highflow. Plus aftermarket gives you a bigger diameter and you don't have that stupid plate blocking the wastegate like the stock DP does. Link to comment Share on other sites More sharing options...
quick4dr Posted February 17, 2010 Share Posted February 17, 2010 what up pipe is recommended/ has the best track record of not cracking? ERZ's has a flex, but invidia does not, gtspec makes great headers is their uppipe just as good? Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted February 17, 2010 Share Posted February 17, 2010 If the only advantage of getting aftermarket pipes is for removing cats, then why would anyone want a catted DP? Are the pipes significantly different length? Or is the DP much more of a restriction due to diameter? Thank you for the input guys, I appreciate it. Like I said, this is uncharted territory so I'm just trying to learn here. Wow you have 1300 posts and have not heard of the issues that can come up with pre-turbo cats and flex pipes? I am NOT bagging on you, just a bit suprised so let me give you cliff notes: In 05-06 GT had a cat in the up, pre turbo. Cats break down over time and bits of it can go INTO your turbo. This generally means turbo failure at minimum and in some cases ends up in complete motor failure. In 07 the cat was removed from the up as it was only there to function when the car is first warming up. Flex pipes, in theory, can come apart and be sucked into the turbo. I am sure someone has had it happen, but I have only read about it. As far as a catted vs uncatted dp, the debate can go long but ultimately catted is quieter and more expensive and we all know pollution is bad. Hiflow race cats wont make a performance difference in your case. Link to comment Share on other sites More sharing options...
dr_sharp Posted February 18, 2010 Author Share Posted February 18, 2010 Hey! I stayed away from performance threads for 60k miles for a reason! Don't judge me! :D Now that warranty is all gone, its time to learn Thanks for the info guys. lol Link to comment Share on other sites More sharing options...
Spec B 127 Posted February 18, 2010 Share Posted February 18, 2010 Yep even a catted DP removes the two stock restrictive cats and replaces them with a highflow. Plus aftermarket gives you a bigger diameter and you don't have that stupid plate blocking the wastegate like the stock DP does. ^-What he said Link to comment Share on other sites More sharing options...
Johnny508 Posted February 19, 2010 Share Posted February 19, 2010 erz also makes u/p?! very interesting.... Link to comment Share on other sites More sharing options...
Spec B 127 Posted February 21, 2010 Share Posted February 21, 2010 erz also makes u/p?! very interesting.... Yes, the one for the 02-07 STi will work on our cars as well. Link to comment Share on other sites More sharing options...
dr_sharp Posted February 21, 2010 Author Share Posted February 21, 2010 erz also makes u/p?! very interesting.... Based on the input of others in this thread, it seems that any LGT that is 07 or newer would not benefit from an UP since they are catless in newer Legacys... someone please correct me if this is wrong. lol Link to comment Share on other sites More sharing options...
m sprank Posted February 21, 2010 Share Posted February 21, 2010 07-09 has no cat in the up. There is no real reason the change one for 99% of applications. Link to comment Share on other sites More sharing options...
dr_sharp Posted February 21, 2010 Author Share Posted February 21, 2010 I ordered the kartoby SSK and ERZ catted DP tonight... :D In 2-3 weeks I'll be stg 2... lol Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted February 21, 2010 Share Posted February 21, 2010 I ordered the kartoby SSK and ERZ catted DP tonight... :D In 2-3 weeks I'll be stg 2... Are you stage zero or stage 1 now? Link to comment Share on other sites More sharing options...
dr_sharp Posted February 21, 2010 Author Share Posted February 21, 2010 Magnaflow exhaust with AP2 (stg 1) for now. lol Link to comment Share on other sites More sharing options...
m sprank Posted February 21, 2010 Share Posted February 21, 2010 You will enjoy stage 2. Link to comment Share on other sites More sharing options...
