wcbjr Posted February 9, 2010 Share Posted February 9, 2010 I'm looking for an aftermarket replacement for #13 pictured below. Is one made? http://img361.imageshack.us/img361/2446/rearsuspensionservicemaru2.jpg I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
wcbjr Posted February 9, 2010 Author Share Posted February 9, 2010 See above. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
Metal2You Posted May 7, 2010 Share Posted May 7, 2010 BUMP. Any after-market trailing arm bushings? Link to comment Share on other sites More sharing options...
FredBeans Posted May 7, 2010 Share Posted May 7, 2010 Working on that for you sir. Link to comment Share on other sites More sharing options...
wcbjr Posted May 7, 2010 Author Share Posted May 7, 2010 I never found one, and I gotta say that it is going to be a PITA to install. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
FredBeans Posted May 7, 2010 Share Posted May 7, 2010 There are spec.b and Grp.N variants. I think Whiteline also makes an insert to plug the holes in the stock bushing. Should just press out and press in... of course removing the trailing arm is another process entirely. Link to comment Share on other sites More sharing options...
The Internet Posted August 12, 2010 Share Posted August 12, 2010 There are spec.b and Grp.N variants. I think Whiteline also makes an insert to plug the holes in the stock bushing. Any chance on aftermarket bushings for 05s? (links to the above mentioned plugs would kick arse as well) I have had no luck in finding ANY aftermarket trailing arm kits. What would cause these to fail? If it;s not due to torque, adjusted camber or "spirited driving" I'll just get the OEM bushings for 20 bucks and be done with these uneventful searches Link to comment Share on other sites More sharing options...
