quick4dr Posted February 8, 2010 Share Posted February 8, 2010 just flashed mickeyd stage 1. how do these logs look?romraiderlog_20100208_145442.csvromraiderlog_20100208_145232.csvromraiderlog_20100208_142305.csv Link to comment Share on other sites More sharing options...
Ridgeracer Posted February 8, 2010 Share Posted February 8, 2010 You don't have to log knock correction advance. Just the knock sum is fine. They all look clean. Are all of these runs 3rd gear pulls? Try to stay at 100% throttle. Also you are not hitting target boost. Are you certain you copied all the correct tables from Mikeyd's spreadsheet into your map? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
E-Tank Posted February 9, 2010 Share Posted February 9, 2010 How do these logs look? http://www.archives.gov.on.ca/english/on-line-exhibits/paper/pics/3297_log_pile_1020.jpg Link to comment Share on other sites More sharing options...
quick4dr Posted February 9, 2010 Author Share Posted February 9, 2010 yes copied them all and mickeyd checked it for me. i just realised i didnt hit wot. what can i check to make sure im getting to target boost? Link to comment Share on other sites More sharing options...
Ridgeracer Posted February 9, 2010 Share Posted February 9, 2010 Check for any leaks in your system. Check the connection from the turbo outlet to the TMIC is secure. Check the throttle body coupling is tight. Check the endtank tabs are secure on the TMIC. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted February 9, 2010 Share Posted February 9, 2010 What's your Atmo. Pressure at? Or how high above sea level are you? You don't need to log it. Just check next time you are in your car with RR on. It could affect your manifold relative pressure, or boost targets, if you live in high altitude, like me. Do a learning view shot as well and post that. www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted February 9, 2010 Share Posted February 9, 2010 you may want to check your airfilter and clean your maf as well. www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
quick4dr Posted February 9, 2010 Author Share Posted February 9, 2010 filter and maf are clean, i live just outside of NYC, in rockland elevation low. all connections seam to be in tact with no leaks using the old blow smoke around to c if it gets pushed by a leak. Link to comment Share on other sites More sharing options...
Ridgeracer Posted February 9, 2010 Share Posted February 9, 2010 Can you download Learn Viewer from Rom Raider and check your fuel trims? That might give some more info. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
quick4dr Posted February 9, 2010 Author Share Posted February 9, 2010 i have learning view, not very sure how to use it, when i connect to ecu it gives me readings but if i drive around it errors and gives me nothing. any ideas? Link to comment Share on other sites More sharing options...
Ridgeracer Posted February 9, 2010 Share Posted February 9, 2010 Are you using it with RomRaider's logger open? Only use one program at a time. Post a pic of the Learn Viewer file. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
