thunderdan Posted February 4, 2010 Share Posted February 4, 2010 im putting on a down pipe/ up pipe and a grimmspeed EBCS on this weekend. and im also getting openecu/RR stage 2 tune. my question is what power number should i see. also how many lbs for boost should i tune for???how many lbs can the TMIC handle?car is an 05lgt wagon 5sp with an drop in air filter and i gutted the stock mufflers. Link to comment Share on other sites More sharing options...
subleg05gt Posted February 4, 2010 Share Posted February 4, 2010 save your money and get a bigger top mount. thats what i did cuz my stock topmount end tanks crack when i was at stage 1with a protune. My boost for the stage 1 was at 16.5. Now i went to stage 2 and to a perrin top mount and a protune from PDX and the boost is at 18psi. Much happier with it runs alot better. Link to comment Share on other sites More sharing options...
brum Posted February 4, 2010 Share Posted February 4, 2010 How'd you go about gutting the stock mufflers? Link to comment Share on other sites More sharing options...
thunderdan Posted February 4, 2010 Author Share Posted February 4, 2010 How'd you go about gutting the stock mufflers? i got pic i will post when i get home Link to comment Share on other sites More sharing options...
GULLABLE0NE Posted February 4, 2010 Share Posted February 4, 2010 i went with a perrin tmic when i started running stage 2 maps but they aren't cheap. many people here have no issues with stage 2 boost levels after the JB weld on stock ICs. i figured im gonna need the bigger core sooner or later so I bought the tmic in a group buy for a good price. Link to comment Share on other sites More sharing options...
thunderdan Posted February 5, 2010 Author Share Posted February 5, 2010 i went with a perrin tmic when i started running stage 2 maps but they aren't cheap. many people here have no issues with stage 2 boost levels after the JB weld on stock ICs. i figured im gonna need the bigger core sooner or later so I bought the tmic in a group buy for a good price. im kind of broke and was going to save for a tmic or a fmic but what is the JBweld on the stock IC?? Link to comment Share on other sites More sharing options...
subleg05gt Posted February 5, 2010 Share Posted February 5, 2010 JB weld you can find it at your local auto store. Just make sure its clean as a whistle cuz you want it to hold. Its strong when its done right. it works, it all depends on who you talk to. I did it to mine and it just crack again. So I upgraded. Link to comment Share on other sites More sharing options...
Strizzy Posted February 5, 2010 Share Posted February 5, 2010 I've been at stage 2 with my stock TMIC for the past 12,000 miles. My peak boost is around 20psi. My bad luck build Link to comment Share on other sites More sharing options...
thunderdan Posted February 5, 2010 Author Share Posted February 5, 2010 i know what JBweld is im asking what do u use the JBweld on?? where do u apply the JBweld on the TMIC strizzy123: what hp/tq numbers did u get? Link to comment Share on other sites More sharing options...
Strizzy Posted February 5, 2010 Share Posted February 5, 2010 On a Mustang dyno (which usually reads low compared to other dynos), I put down 238hp and 290tq at the wheels. My bad luck build Link to comment Share on other sites More sharing options...
NJLGT Posted February 5, 2010 Share Posted February 5, 2010 I have been running 20 psi on my stock tmic for over a year with no ill effects. Link to comment Share on other sites More sharing options...
GULLABLE0NE Posted February 5, 2010 Share Posted February 5, 2010 i went for the perrin tmic because i didnt want to blow my stock IC and get caught out there with nothing, then either wait for parts or figure out a temporary solution. the piece of mind knowing im not gonna blow the perrin IC helps me sleep at night with my big head on my litttle pillow. do it right the first time or leave yourself vulnerable to part failure. Link to comment Share on other sites More sharing options...
NJLGT Posted February 5, 2010 Share Posted February 5, 2010 i prefer to be daring, knowing that my ic could blow at anytime and cause a massive explosion killing me the surrounding bystanders Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted February 5, 2010 Share Posted February 5, 2010 I have been running 20 psi on my stock tmic for over a year with no ill effects. What will telling will be when NJLGT has a tuned to 20psi date and a popped stock tmic date. I want to know how long one could hope to get away with it! How many licks does it take to get to the center of a tootsie roll tootsie pop? FMIC may never know... Link to comment Share on other sites More sharing options...
midslik Posted February 5, 2010 Share Posted February 5, 2010 I just ordered a down and up pipe new turbo inlet and cbe and a cobb accessport currently Ive been running a stage 1 tune at 16.4 psi peak boost and have had no issue guess we will see if i do in a week or so when the parts and new tune go on Link to comment Share on other sites More sharing options...
05_Silver_GT Posted February 5, 2010 Share Posted February 5, 2010 bump Link to comment Share on other sites More sharing options...
thunderdan Posted February 6, 2010 Author Share Posted February 6, 2010 got the dp/up installed wait for the roads in MN to dry out to tune/ EBCS Link to comment Share on other sites More sharing options...
peteyjr Posted February 6, 2010 Share Posted February 6, 2010 18 psi is the usual stage II goal . Link to comment Share on other sites More sharing options...
NJLGT Posted February 6, 2010 Share Posted February 6, 2010 What will telling will be when NJLGT has a tuned to 20psi date and a popped stock tmic date. I want to know how long one could hope to get away with it! How many licks does it take to get to the center of a tootsie roll tootsie pop? FMIC may never know... :confused: I'll definatly post it up if it ever goes... I doubt it though because I don't beat on my cars. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted February 11, 2010 Share Posted February 11, 2010 :confused: I'll definatly post it up if it ever goes... I doubt it though because I don't beat on my cars. Please post it and pics if it ever does go! I am not hoping your TMIC comes apart, rather, I am waiting to see how long (your) TMIC can survive 20psi (which is overboosting the stock TMIC and is, in fact, beating on your car). Oh, "FMIC may never know..." I am tossing in a RacerX FMIC so I will never know about poping the TMIC. Link to comment Share on other sites More sharing options...
