Steve R. Posted October 8, 2014 Share Posted October 8, 2014 all 06+WRX and 07+ LGT flywheels are suppose to be the same. All but the STI and specB models, and non turbo models. Link to comment Share on other sites More sharing options...
apexi Posted October 8, 2014 Share Posted October 8, 2014 For what it's worth it looks just like the single mass flywheel that came out of a 2005 non turbo legacy in the link below. The FSM says non-turbo 2005's came with a "conventional" flywheel. http://legacygt.com/forums/showthread.php/need-clarification-flywheel-service-219022.html Link to comment Share on other sites More sharing options...
Max Capacity Posted October 8, 2014 Share Posted October 8, 2014 Redryan, I'd be worried about using that FW unless you find out the PP has the step on the mounting points. Based on that other link "apexi" sent, I'm thinking you have a 2.5i FW there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Redryan98 Posted October 8, 2014 Share Posted October 8, 2014 Looks like you're right guys. I'll have to talk with the seller since he swears it came out of a GT. Link to comment Share on other sites More sharing options...
birkhoff Posted April 8, 2016 Share Posted April 8, 2016 For those of us still using (and re-using) the DM setup, could you say how much rotational play there is in your brand new DMFW? Say, xx mm at the rim of the centre casting? This doesn't seem to be covered in the FSM under inspection. Link to comment Share on other sites More sharing options...
