captainhook Posted January 15, 2010 Share Posted January 15, 2010 It doesn't make any sense to buy a new car if you don't need one does it? I buy a car to run it into the friggin' ground. That's typically a pretty financially savvy call . . . assuming you have a reliable vehicle and replacement parts are reasonably priced. If the cost of ownership keeping it is going to end up costing you more than the payments on a new car, however, you may as well make the trade. My LGT is going to be history before the warranty runs out for that reason alone. Link to comment Share on other sites More sharing options...
coldmm803 Posted January 15, 2010 Share Posted January 15, 2010 AWD, yes . . . engines, not so much as of late, lol. all manufacturers are going to have issues, no way around that I am an engineer (not for cars but that is irrelevant). Our purchasing people change vendors for a part because the new one will make a part for less $ and then parts don't assemble the way they should/ used to and stuff stops working properly. Even parts that we have made for 4+ years can stop fitting all of a sudden because a vendor hired someone new or tooling wore down and a dimension changes by the thickness of a hair. It would probably be easier to build an engine because tolerances can be looser than we use because engines have oil to keep the parts from touching and binding Link to comment Share on other sites More sharing options...
