ZacWasHere Posted January 7, 2010 Share Posted January 7, 2010 hey my legacy sedan needs some help that i can seem to provide. alright it seems like i have a loss in power before 4 grand, like almost to stall point. i don't know how else to say whats wrong than it feels like she has decided to apply the brakes until 4100.92 legacy ej22 na.feel free to ask any needed questions because i really don't know much about subarus unfortunately. thank you for any insight ps skipped info on accident: smells a little rich at times and occasional misfire Link to comment Share on other sites More sharing options...
ehsnils Posted January 7, 2010 Share Posted January 7, 2010 Not much info to go on. I would suggest that you start with checking that everything is in good order - vacuum hoses, no codes on the ECU and if you have a MAF sensor - that it's clean. Injector cleaner may also help. It is also possible that there are modifications causing this. A change in air intake can cause incorrect resonance that messes up things. A bad sensor is another thing, especially throttle position and/or manifold pressure. And make sure that the ignition system is in good working order. Fresh spark plug cables, clean ignition coils and new spark plugs. Link to comment Share on other sites More sharing options...
ZacWasHere Posted January 8, 2010 Author Share Posted January 8, 2010 new plugs wires and the coils are pretty clean. put a new air filter in but it was just a stock sized k&n one. haven't really checked maf, im a carburated guy so i forget that often. i'll check for codes. and vacuum hoses seem alright to me ps thank you for responding Link to comment Share on other sites More sharing options...
Platinum_Racing Posted January 8, 2010 Share Posted January 8, 2010 Like said before, check all vacuum lines and spark plug wires. These cars had an issue with the Phase I EJ22 ignition coil where buildup would occur in the terminals for the spark plug wires. I had a problem with it last year that made the car VERY hard to start in cold weather. Once I cleaned the coil pack the problem went away. Is it a hesitation or a total loss in power? Does the car accelerate like normal, then bog, then continue to accelerate again, or does it just get louder and go nowhere until it crawls to 4G's? Link to comment Share on other sites More sharing options...
ZacWasHere Posted January 8, 2010 Author Share Posted January 8, 2010 hesitation and gets louder/crawls till 4 then its just like nothing happened Link to comment Share on other sites More sharing options...
ZacWasHere Posted January 20, 2010 Author Share Posted January 20, 2010 so i cleaned the coil again and it performed a lot better in first and kinda better in second. also checked maf and it was excessively cleaner than i could have imagined. o and ehsnils i tried injector cleaner first. is it any possibility that the fuel pump is going out? also my battery was heading toward death before i parked her and now its frankly needing replaced. the alt was replaced sometime before i acquired the car with a mitsubishi one. any other ideas? Link to comment Share on other sites More sharing options...
ehsnils Posted January 23, 2010 Share Posted January 23, 2010 It can be that you have a hairline fracture in the coil that will force you to replace it, or it can be the fuel pump. Try to check the fuel pressure while driving. That would give a good idea of if it is the pump. Link to comment Share on other sites More sharing options...
ZacWasHere Posted January 24, 2010 Author Share Posted January 24, 2010 and how do i check fuel pressure while driving Link to comment Share on other sites More sharing options...
