sealdogfish Posted December 29, 2009 Share Posted December 29, 2009 Hi, I need help diagnosing a coolant leak on my 94 Subaru Legacy GT just above the exhaust on the passenger side (behind turbo) there is a thick hose that comes out of the firewall and is open. it is steadily leaking coolant. Does this mean that my heater core is leaking or is this from somewhere else? Thanks. Link to comment Share on other sites More sharing options...
sealdogfish Posted December 29, 2009 Author Share Posted December 29, 2009 to clarify: the hose from the firewall is the ac drain hose but it is leaking coolant from the engine. any ideas? Link to comment Share on other sites More sharing options...
Platinum_Racing Posted December 29, 2009 Share Posted December 29, 2009 It could be the heater core. If it was leaking inside the shroud for the heater chances are you would notice a mist of coolant whenever you turned on the vents with the heat on. Heater core is my guess. Link to comment Share on other sites More sharing options...
