Andreu Posted December 4, 2009 Share Posted December 4, 2009 Everytime I get out of my car after a drive my car smells like I slipped the clutch or something else is burning. Anyone have any clues? Link to comment Share on other sites More sharing options...
aigochamaloh Posted December 4, 2009 Share Posted December 4, 2009 Are you slipping the clutch? If it's an OEM clutch, they stink pretty badly and very easily. Link to comment Share on other sites More sharing options...
Scotty Posted December 4, 2009 Share Posted December 4, 2009 Like burning grease? If it does, look at your downpipe. Is it cover with grease? If it is, check you CV boot, most likely it is cracked and the grease is running out. I just had mine replaced today. Link to comment Share on other sites More sharing options...
Andreu Posted December 4, 2009 Author Share Posted December 4, 2009 i dont slip the clutch that bad, i usually stay below 2k rmp when starting out Link to comment Share on other sites More sharing options...
808LGT Posted December 4, 2009 Share Posted December 4, 2009 best thing to do is call a mechanic friend or bring it to a shop you trust to have it looked at Like burning grease? If it does, look at your downpipe. Is it cover with grease? If it is, check you CV boot, most likely it is cracked and the grease is running out. I just had mine replaced today. but this is the most likely case, since i did crack one of my boots when i had my 05 Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted December 4, 2009 Share Posted December 4, 2009 i dont slip the clutch that bad, i usually stay below 2k rmp when starting out Well its really how long you are slipping the clutch. Link to comment Share on other sites More sharing options...
ktmrider Posted December 4, 2009 Share Posted December 4, 2009 like burning grease? If it does, look at your downpipe. Is it cover with grease? If it is, check you cv boot, most likely it is cracked and the grease is running out. I just had mine replaced today.+1... Link to comment Share on other sites More sharing options...
Molal24 Posted December 4, 2009 Share Posted December 4, 2009 I know this was a problem last winter. I doubt this would be the problem yet but during the winter months, the crap that street crews spray on the roads causes the cars to stink pretty bad... Link to comment Share on other sites More sharing options...
The_Bishop Posted December 4, 2009 Share Posted December 4, 2009 I would second the CV boot thought from above, or even an oil leak from another source....I recently removed my Oil Control Valves (OCV) and had the smell you describe temporarily...must have not cleaned up the oil quite good enough and it traveled down around the head to the exhaust manifolds. I could smell it once stationary after driving the car...like it was coming through the air vents. - Allen. Link to comment Share on other sites More sharing options...
bryanf Posted December 4, 2009 Share Posted December 4, 2009 Look at the oil rebreather line...it connects to the valve cover on the top of the engine. One of mine popped off and would cause an oily smell particularly after sustained high revs. Just pop it back on--I added a hose clamp to prevent it from coming off again. Link to comment Share on other sites More sharing options...
bryanf Posted December 4, 2009 Share Posted December 4, 2009 Hey The-Bishop, nice looking Elise! Is it yours? I just bought a polar blue '06 that I'm lovin' Link to comment Share on other sites More sharing options...
jigga Posted December 5, 2009 Share Posted December 5, 2009 Look at the oil rebreather line...it connects to the valve cover on the top of the engine. One of mine popped off and would cause an oily smell particularly after sustained high revs. Just pop it back on--I added a hose clamp to prevent it from coming off again. agreed.. This is something to definitely have a look at. If it is letting off oil vapor underneath the bonnet, everyone riding inside the car will smell as if they work for an oil refinery after coming out of the car.. Link to comment Share on other sites More sharing options...
