dubunderpar Posted December 3, 2009 Share Posted December 3, 2009 Since I already own an xm reciever from another car and I just found out that the kit for my outback was going to run me $300+ I am just going to use my old set up. Looking through the front there aren't many options, but I was wondering where some of you mounted or hid them. Link to comment Share on other sites More sharing options...
bigdadi Posted December 4, 2009 Share Posted December 4, 2009 clamp style / suction cup holder mounted on most left dash or vent mounted in middle. There is also adapter plate hardware mounting on left side of radio, using the 1 of 3 radio screws. Link to comment Share on other sites More sharing options...
BLACKeNeD Posted December 4, 2009 Share Posted December 4, 2009 I mounted mine with a bracket between the shift plate and the seat warmers. I think I have my install pics int his thread, post #62 Link to comment Share on other sites More sharing options...
dubunderpar Posted December 4, 2009 Author Share Posted December 4, 2009 What post? Link to comment Share on other sites More sharing options...
CwhillVT Posted December 4, 2009 Share Posted December 4, 2009 http://legacygt.com/forums/showpost.php?p=1430990&postcount=9 I also routed my antenna wire under the carpet to the rear and put the antenna inside of the third brake light housing.(no pics) Works great. Link to comment Share on other sites More sharing options...
BLACKeNeD Posted December 4, 2009 Share Posted December 4, 2009 Sry. This post Link to comment Share on other sites More sharing options...
c-lo Posted December 5, 2009 Share Posted December 5, 2009 I stuck my roady2 in the cubby pod. drilled a hole in the back for the cables and ran the antenna wire up along the roof line behind the trim. the antenna itself is stuck up on my roof in the middle/back. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
dubunderpar Posted December 5, 2009 Author Share Posted December 5, 2009 I ran all the wires tonight, mounting it in the morning right above seat heater switch and to the right. I think its going to look good I will post pics when it's all done. Link to comment Share on other sites More sharing options...
Freeskier_22 Posted December 5, 2009 Share Posted December 5, 2009 dub where are you mounting the antenna at? Link to comment Share on other sites More sharing options...
LegacyGTBiggie Posted December 5, 2009 Share Posted December 5, 2009 Mines in the cubby with a home made brace to keep it to the front. antenna run to the trunk and then up on top of it. Link to comment Share on other sites More sharing options...
dubunderpar Posted December 5, 2009 Author Share Posted December 5, 2009 I ran the antenna all the way to the back cenetered in front of the rear hatch. I thought about putting it in the cubby, but it was too tall with the cradle, and I wouldn't have been able to close it. Link to comment Share on other sites More sharing options...
