tedsan126 Posted November 28, 2009 Share Posted November 28, 2009 I have a 95 legacy ej22. And i was wondering if the ej25d would be a direct plug in Link to comment Share on other sites More sharing options...
Platinum_Racing Posted November 28, 2009 Share Posted November 28, 2009 EJ25D is a direct bolt-in, but not a direct plug in. You will need the EJ25D ECU. The EJ25D exhibits leaking head gaskets and a power band higher in the RPM range than the EJ22. A swap wouldn't be worth it performance wise. You might get more horsepower, but when the head gaskets starts leaking you'll wish you kept the EJ22. Link to comment Share on other sites More sharing options...
tedsan126 Posted November 29, 2009 Author Share Posted November 29, 2009 so would it be more worth it to keep the ej22 and do the head swap like i was talking about before? And if yes how am i going to go about it Link to comment Share on other sites More sharing options...
Platinum_Racing Posted November 29, 2009 Share Posted November 29, 2009 Buy the heads, bolt them on, use new EJ22 head gaskets, and get a new EJ25 DOHC timing belt. Throw it all together, wire it up, and hope it works. Link to comment Share on other sites More sharing options...
