veritas Posted November 26, 2009 Share Posted November 26, 2009 Let me preface really quickly. About a month ago I put new DRL bulbs in my 08 LGT. I also replaced the fogs making sure I got the right bulbs and that they were installed properly. Lights looked good but i drive aroubd during the day mostly and live in NYC where there is a lot of ambient light. 3 days later never having driven the car at night someone backs into the front of my car in a parking lot...hard. 4k in damage new, bumper, hood supports yada yada. The headlight were saved. I have the stock headlight bulbs in place. Just the DRL's and fogs were changed. The issue i'm having is with the headlights on and not the highbeams. 3 weeks later I got the car back and promptly put a new pair of CF eyelids on the car, I hadn't even driven the car at night to this point after getting it back from the body shop. My wife and I go visit my parents upstate NY. very dark roads and such. the eyelids are from R-rev. There is this "line" or beam cutoff so to speak thats very visible where the beam ends and it runs across the middle of the road. It's sort of annoying.Thing is, I don't remember it being there but I'm pretty sure it wasn't. it reflects off the trees on the side of the road and is pretty pronounced. My questions are. Does anyone with eye-lids have this problem? If not, could my headlights be out of alignment after the hit and having the body shop taking them on and off a ton of times trying to get everything to fit right. I wanna try and avoid peeling the eyelids off first because there on there pretty good Thanks for any help. I just noticed this tonight on the drive up so I figured I'd post now to get some info before I start messing with the eyelids or headlights. Thanks for any help and happy turkey day, Vin C NYC Link to comment Share on other sites More sharing options...
Impulse Posted November 26, 2009 Share Posted November 26, 2009 99% its misaligned head lights and you're getting something confused with the built in cutoff shield in the lens. the cutoff is meant to prevent on comming cars from being blinded. you might just need to adjust it up *a bit* look something like this?: (ignore the *s) ***********________ __________/ Link to comment Share on other sites More sharing options...
veritas Posted November 26, 2009 Author Share Posted November 26, 2009 I think the line was even across both lights just right in my eyeline. I'm gonna try and align them tonight. I think I'd rather try that than risk snapping one of my eyelids taking them off, lol. The 3m tape I used to put them on is some sticky stuff. Thanks for the reply. Link to comment Share on other sites More sharing options...
BigInALegacy Posted November 26, 2009 Share Posted November 26, 2009 I get no cutoff with my RBS eyelids on my 2008. If you have to remove them though, use a hairdryer to loosen the tape and take it slow and steady. GL Link to comment Share on other sites More sharing options...
veritas Posted November 26, 2009 Author Share Posted November 26, 2009 Thanks man, I'll try. Anyone else have any experience. Something else to add. When I put my high beams on along with my headlights it almost seems like you can see the line between where the headlight beam ends and where the high beam begins. Link to comment Share on other sites More sharing options...
m sprank Posted November 26, 2009 Share Posted November 26, 2009 Sounds like misalignment. Not an issue with eyelids. Link to comment Share on other sites More sharing options...
veritas Posted November 27, 2009 Author Share Posted November 27, 2009 Checked it last night again, they are def out of alignment. right side is higher than the other. Thanks guys. Link to comment Share on other sites More sharing options...
veritas Posted December 7, 2009 Author Share Posted December 7, 2009 Update, I took my car into the dealership for an oil change and asked him to check my headlights because I thought they were out of alignment...Well, to my suprise he said they were fine and my eyelids were not affecting the beam either. Wtf? Even my wife commented on it how it looked weird and my wife doesn't know shit, lol. I'm gonna try and post some pics, but I need to find a really dark street. Should the beam cutoff be closer to the ground or above the windshield and high? Link to comment Share on other sites More sharing options...
Blue GT Posted December 7, 2009 Share Posted December 7, 2009 cutoff should be closer to the ground, the cutoff is where the shield inside the headlight stops light from blinding other drivers, so it cant be up high it would defeat the purpose. And while most wives don't know anything about cars they can spot certain basic things that they can see, mine does. Link to comment Share on other sites More sharing options...
Beanboy Posted December 7, 2009 Share Posted December 7, 2009 As somebody outlined above, right passenger side is higher than left. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
veritas Posted December 7, 2009 Author Share Posted December 7, 2009 Gonna try and snap some pics, but everyone is leading me to believe it's just normal and I never noticed it and assumed it was an issue after the car was hit. Let me ask you guys this: When you have ur headlights on and u put ur brights on are you supposed to see the beam cutoff where the headlights end and where the highbeams begin? Link to comment Share on other sites More sharing options...
rice_rocket Posted December 7, 2009 Share Posted December 7, 2009 99% its misaligned head lights and you're getting something confused with the built in cutoff shield in the lens. the cutoff is meant to prevent on comming cars from being blinded. you might just need to adjust it up *a bit* look something like this?: (ignore the *s) ***********________ __________/ Yup like dat.. even more apparent with my HID's If it's not misaligned.. you probably just never noticed it Link to comment Share on other sites More sharing options...
