JSK05LGT Posted November 17, 2009 Share Posted November 17, 2009 Changed my battery today from the original OEM to an Optima Yellow top (left my interior lights on by accident over night and battery died) and upon starting the car I got the CEL (P0103) which is the High Voltage MAF code. Tried re-flash, tried ecu reset, code persists. Before everyone starts asking, the battery was installed properly, no touching connections etc. Simple swap and go, car fired right up no problem, but it appears to have shorted the MAF sensor some how... Any thoughts, or was it just time to finally have something fail after 107K miles? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 18, 2009 Share Posted November 18, 2009 IMO just bad luck, nothing to do with the battery. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JSK05LGT Posted November 18, 2009 Author Share Posted November 18, 2009 Thats what im thinking... Link to comment Share on other sites More sharing options...
GTTuner Posted November 18, 2009 Share Posted November 18, 2009 Watch out for the wires where they enter the plug at the MAF, sometimes because of the wires bending the conductor inside the wire breaks. A circuit high code is just that, voltage is high most likely due to an open circuit. Link to comment Share on other sites More sharing options...
JSK05LGT Posted November 18, 2009 Author Share Posted November 18, 2009 I will take a look at that, the funny thing is, prior to changing the battery, the MAF had not been touched in months! I guess next thing to replace in the event the new sensor doesnt work (comes in tomorrow) is to try and replace the wiring running to the MAF sensor. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted November 19, 2009 Share Posted November 19, 2009 Well the battery and MAF are on opposite sides of the car... [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
JSK05LGT Posted November 19, 2009 Author Share Posted November 19, 2009 My thought exactly, the more I think about it, the more it is just a coincidence. Just an odd one considering the MAF sensor seems to be a rare part to fail. Link to comment Share on other sites More sharing options...
HarryN Posted November 19, 2009 Share Posted November 19, 2009 My thought exactly, the more I think about it, the more it is just a coincidence. Just an odd one considering the MAF sensor seems to be a rare part to fail. Not really if you ask the people that put in those intake mods. They have a tendency to "break out of nowhere". But when doing things like installing a battery, that truly IS rare. Maybe there was a surge? How did you connect your battery? Negative first then Positive? Link to comment Share on other sites More sharing options...
JSK05LGT Posted November 20, 2009 Author Share Posted November 20, 2009 Nope, Positive first then Negative. Perhaps it was the intake modification. Regardless, replaced the MAF Sensor today and reset the code and all is well. Now time to install the new GrimmSpeed TGV Deletes and retune! Link to comment Share on other sites More sharing options...
HarryN Posted November 20, 2009 Share Posted November 20, 2009 Nope, Positive first then Negative. Perhaps it was the intake modification. Regardless, replaced the MAF Sensor today and reset the code and all is well. Now time to install the new GrimmSpeed TGV Deletes and retune! Awesome!!! *queue porn music* Link to comment Share on other sites More sharing options...
NJLGT Posted November 20, 2009 Share Posted November 20, 2009 this happened to me, no big deal, i just cleared it with my ap... nothing to worry about in the long run. Link to comment Share on other sites More sharing options...
