Changed battery, caused MAF sensor failure...
Changed my battery today from the original OEM to an Optima Yellow top (left my interior lights on by accident over night and battery died) and upon starting the car I got the CEL (P0103) which is the High Voltage MAF code. Tried re-flash, tried ecu reset, code persists. Before everyone starts asking, the battery was installed properly, no touching connections etc. Simple swap and go, car fired right up no problem, but it appears to have shorted the MAF sensor some how... Any thoughts, or was it just time to finally have something fail after 107K miles?
I will take a look at that, the funny thing is, prior to changing the battery, the MAF had not been touched in months! I guess next thing to replace in the event the new sensor doesnt work (comes in tomorrow) is to try and replace the wiring running to the MAF sensor.
My thought exactly, the more I think about it, the more it is just a coincidence. Just an odd one considering the MAF sensor seems to be a rare part to fail.
Not really if you ask the people that put in those intake mods. They have a tendency to "break out of nowhere". :lol:
But when doing things like installing a battery, that truly IS rare. Maybe there was a surge? How did you connect your battery? Negative first then Positive?
Nope, Positive first then Negative. Perhaps it was the intake modification. Regardless, replaced the MAF Sensor today and reset the code and all is well. Now time to install the new GrimmSpeed TGV Deletes and retune! :)
Awesome!!! *queue porn music*
