QToo Posted November 17, 2009 Share Posted November 17, 2009 I have an 05 GT and ever since I got new tires this summer, I am having a pull to the right. We tried swapping tires from side to side and front to back but still the same. Did a 4 wheel alignment and back to factory specs, but the pull is still there. Seems to be worse when I let off the gas and coast versus when under power. Any ideas on what may be causing this to occur? could it have to do with the wheel bearing recall issue? I was thinking that if the bearing was bad on one side, then it would create more friction on one side causing the car to go to the right. This would be magnified when not under power. 90K miles on the car. Thanks Link to comment Share on other sites More sharing options...
devobuzz Posted November 17, 2009 Share Posted November 17, 2009 Sticky right front caliper? Link to comment Share on other sites More sharing options...
scoobydoobie Posted November 17, 2009 Share Posted November 17, 2009 You'd know if it was a bad wheel bearing. (lots of noise) Check your CV boots. Link to comment Share on other sites More sharing options...
GTTuner Posted November 18, 2009 Share Posted November 18, 2009 Post your alignment settings so I can see them. Link to comment Share on other sites More sharing options...
AShoe Posted November 18, 2009 Share Posted November 18, 2009 I would look for a torn or cracked suspension bushing. Link to comment Share on other sites More sharing options...
QToo Posted November 30, 2009 Author Share Posted November 30, 2009 Thanks for the feedback. Sorry it has taken so long to get back to this, work and kids sports have been calling. I was finally able to get under the car this weekend. when checking out the bushings, I noticed that the steering arm (is this the tie-rod?) was easy to rotate to the extremes. When I moved it up and down, some grease or fluid started to come out. Looks like this is probably the culprit. How difficult to change these out? Looked fairly straight forward. I will do a search, but have others gone the urethane route? Thanks again Link to comment Share on other sites More sharing options...
QToo Posted November 30, 2009 Author Share Posted November 30, 2009 Here is a picture of what I am talking about. The bushing at the end of the steering arm, but I am not sure what this is called. Any help would be appreciated. Link to comment Share on other sites More sharing options...
sashadg1 Posted November 30, 2009 Share Posted November 30, 2009 Yes this a steering bushing an if it is worn and or loose your vehicle will wonder or pull which ever way which ever way with the least resistance. You may want to check all of them. The fact it's torn an leaking tells me it may have been like this and when this happens it applies undue stress on the ball and socket. It may be the problem, could be corected by adjusting alignement to counter still within specs. Just because it's in the green does not mean everything is good, just really close. Scott Link to comment Share on other sites More sharing options...
