Hanslo Posted November 15, 2009 Share Posted November 15, 2009 I was trying to take off the top nut on one of my front struts and thought I was making good progress. I then realized I was just spinning the strut shaft. I must have spun it around at least 10 full revolutions. Is this harmful? I was working on an assembled stock GT(KYB) suspension unit in my basement - not on the car. Thanks, Hanslo Link to comment Share on other sites More sharing options...
zenfamily Posted November 15, 2009 Share Posted November 15, 2009 No, it shouldn't be an issue Link to comment Share on other sites More sharing options...
andyarmada Posted November 16, 2009 Share Posted November 16, 2009 No. I believe the 2005+ Legacys have bearings built into the top hat between the spring and the hat, that let's it spin. Should be fine. Link to comment Share on other sites More sharing options...
naimouasta Posted November 16, 2009 Share Posted November 16, 2009 i think all tophats can spin. atleast for the fronts. thats how the wheel turns. Link to comment Share on other sites More sharing options...
Hanslo Posted November 16, 2009 Author Share Posted November 16, 2009 The tophat does spin freely on top of the assembly. What i'm talking about is the shaft of the strut was turning inside the strut housing as I was trying to loosen the top nut. I knew to watch for this and even had my index finger touching the shaft but the shaft is so smooth I didn't feel it moving under my finger. Link to comment Share on other sites More sharing options...
zenfamily Posted November 16, 2009 Share Posted November 16, 2009 You should still be good to go. I had Konis before, and spun the shaft. Link to comment Share on other sites More sharing options...
Hanslo Posted November 16, 2009 Author Share Posted November 16, 2009 You should still be good to go. I had Konis before, and spun the shaft. Thanks Zen. There doesn't seem to be any sign of damage but I just wanted to be sure. Link to comment Share on other sites More sharing options...
GTTuner Posted November 16, 2009 Share Posted November 16, 2009 As long as you didn't spin it up with an impact gun your fine. You could turn it all day by hand and it wouldn't hurt it. Link to comment Share on other sites More sharing options...
Hanslo Posted November 16, 2009 Author Share Posted November 16, 2009 As long as you didn't spin it up with an impact gun your fine. You could turn it all day by hand and it wouldn't hurt it. Ok, good. No impact wrench just by hand. I now have a brand new shiny pass-through socket wrench set - very helpful. Hanslo Link to comment Share on other sites More sharing options...
