dante2699yahoo.com Posted November 11, 2009 Share Posted November 11, 2009 How do you check for a vacuum hose leak? Link to comment Share on other sites More sharing options...
kaz98gt Posted November 11, 2009 Share Posted November 11, 2009 soapy water solution. if you know a general area for a leak, make up some water w soap and put it on any suspected hoses. if you see after a little bit, there's a leak. Link to comment Share on other sites More sharing options...
rmb2485 Posted November 12, 2009 Share Posted November 12, 2009 Soapy water won't help because a vacuum leak would be sucking air in, not blowing air out. Check your vacuum hoses and plastic connectors. A crack would usually be pretty obvious, but you can also listen for a whistle or feel for a leak around all the vacuum components while the motor is running. Link to comment Share on other sites More sharing options...
