naimouasta Posted November 9, 2009 Share Posted November 9, 2009 just saw these new style STi pedals. the description says, "2010 Impreza STi pedal set". previously you were unable to buy the aluminum pedal set for the 07-09 legacy's because of the "plastic" gas pedal assembly. assuming that 08-10 impreza's are the same, they would also have this new style "plastic" gas pedal, therefore these should fit the 07-09 legacy's? Link to comment Share on other sites More sharing options...
DJ Doc Posted November 13, 2009 Share Posted November 13, 2009 bump Link to comment Share on other sites More sharing options...
m sprank Posted November 13, 2009 Share Posted November 13, 2009 I made STi pedals fit my 08 LGT 5EAT. Just had to drill trough the plastic for the mount. Link to comment Share on other sites More sharing options...
naimouasta Posted November 13, 2009 Author Share Posted November 13, 2009 do you have the pink sti pedals? or do you have the regular aluminum pedals? i think the pink ones you screw on. the regular aluminum pedals (which i wanted), are actual pedals, where you had to knock out the pin for the gas pedal. i did this for my brothers 2.5RS which was simple, but is not possible for the new style "plastic" gas pedal. what i'm wondering is how these new type pedals are installed. Link to comment Share on other sites More sharing options...
m sprank Posted November 13, 2009 Share Posted November 13, 2009 I have the Aluminum STi pedals. My wife has the car now. Once shes home I will snap a pic. I had to get down under the dash (with my cordless drill) and use a shortened drill bit to get in the tight fit. Then I had to drill through the plastic pedal (just below the existing pin as I remember). Then I installed the STi pedal using my holes to insert the new pin through. I can't remember all the exacts. I remember being PISSED when I realized the plastic gas pedal was not coming out. When I take the pic I will verify my drilling location and pin location. It was a bitch. But where theres a will, theres a way. Its been in for about 20000 miles with no issues. Link to comment Share on other sites More sharing options...
underscore Posted November 19, 2009 Share Posted November 19, 2009 Saw this on Nasioc, they were talking about some for the 2010 Legacy and they confirmed it was for plastic pedals and might fit older ones: http://forums.nasioc.com/forums/showthread.php?t=1876205 The model numbers seem to be the same for the 2010 Impreza and Legacy: C8110FG000 for automatic, C8110FG010 for manual. Link to comment Share on other sites More sharing options...
05lgt5spd Posted November 19, 2009 Share Posted November 19, 2009 ttp://www.legacygt.com/forums/showthread.php?t=120865&highlight=fs+spec+pedal here you go Link to comment Share on other sites More sharing options...
naimouasta Posted November 19, 2009 Author Share Posted November 19, 2009 no thanks! these pedals are new style, new, and cheaper. Link to comment Share on other sites More sharing options...
E-Tank Posted November 20, 2009 Share Posted November 20, 2009 I like those...and they would have matched my dead pedal. Too bad I already got the WRX ones. A little STI gear is fun, as long as it's not moronic badges on the lid and the grill. Link to comment Share on other sites More sharing options...
tjbev21 Posted November 20, 2009 Share Posted November 20, 2009 op you got a link to the pedals? does the 05 have the pastic pedal as well or does ours come off Link to comment Share on other sites More sharing options...
naimouasta Posted November 20, 2009 Author Share Posted November 20, 2009 i first saw them here https://www.chaplinssubarugenuineparts.com/product_info.php?cPath=31_119_125&products_id=1625 i'm not sure if yours is plastic or not. just take a look to be sure. if its plastic, the pedal and arm should be completely plastic, if not then the pedal is rubber and the arm is metal. Link to comment Share on other sites More sharing options...
tjbev21 Posted November 20, 2009 Share Posted November 20, 2009 thank you sir... and im almost positive i have a metal arm Link to comment Share on other sites More sharing options...
Warbaby Posted December 30, 2009 Share Posted December 30, 2009 So did anyone ever confirm if these 2010 pedals do fit the 05-06s and/or the 07-09s? My 2006 Legacy GT wagon appears to have a plastic gas pedal. I'm still confused on what the difference was between the 05-06s and 07-09s. Thanks for the help! Link to comment Share on other sites More sharing options...
Warbaby Posted January 17, 2010 Share Posted January 17, 2010 Bump, did anyone ever figure out which years that these pedal covers might fit on? Thanks again! Link to comment Share on other sites More sharing options...
Bolksey85 Posted January 24, 2010 Share Posted January 24, 2010 These are cheaper and have an option for a rubber/plastic pedal. http://www.fastwrx.com/bialpeset.html Link to comment Share on other sites More sharing options...
Windy Road Posted January 24, 2010 Share Posted January 24, 2010 These are cheaper and have an option for a rubber/plastic pedal. http://www.fastwrx.com/bialpeset.html Would they work in our cars with the optional STI metal pedals? My metal pedals are showing some wear and I'm looking for something a bit more grippier. 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
Bolksey85 Posted January 24, 2010 Share Posted January 24, 2010 Would they work in our cars with the optional STI metal pedals? My metal pedals are showing some wear and I'm looking for something a bit more grippier. Not sure. Shoot Dan @ Mach V a PM and see what he has to say. He's the one who gave me a heads up on these as an option for the plastic pedal cars. Link to comment Share on other sites More sharing options...
TSiWRX Posted February 20, 2010 Share Posted February 20, 2010 http://www.subaruforester.org/vbulletin/f77/2010-jdm-sti-pedals-set-installed-63817/ ^ My install on my '05 LGT (5MT) is a bit different. The clutch and brake pedals were easy, but the gas pedal did require a bit of jury-rigging. Instead of doing what the above reference thread's author did, I simply clipped the top over the factory plastic gas pedal, and then used a Dremel to cut/shave the areas of the factory plastic pedal to accommodate where the two "side wings" that make up the support struts for the central pin needed to go. Without relieving this area, the factory pedal proved too wide, causing the struts to displace too far apart (and thus also at an angle), which made it impossible for the central pin to span the two sides. Modified, the gas-pedal pedal-cover fits like the proverbial glove, and I didn't even need to remove the pedal assembly from the car. The pedal, of course, rotates about the pin as it needs to, and WOT travel is uninhibited. Note: I did not use the "collar" (part no. 12). All in all, it was a 15-minute job. No, I didn't get the dead-pedal (I got this 3-pedal kit, new, from Crawford's "Garage Sale," for a blistering $85 or so, including shipping! ), and am happy to keep my old Razo piece, which matches decently well. I haven't driven with the new pedals, yet - but even playing around in the garage afterwards, it's clear that it's going to take me a bit of time to get used to the new set, after having spent the last 16 (I kid you not, that's sixteen - as in I carried my old Razo set from one car to the next, since 1994) years with my previous set...... <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
DJ Doc Posted February 20, 2010 Share Posted February 20, 2010 This sounds like a "yes" to the OP, that they will fit on an 07-09... Link to comment Share on other sites More sharing options...
TSiWRX Posted February 20, 2010 Share Posted February 20, 2010 As long as your BL/BP ('05-'09) has a plastic gas pedal, it's an easy modification. A metal pedal will require more modification, but I'm pretty confident that if I were presented with that problem, I could still pretty easily make it fit. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
DJ Doc Posted February 20, 2010 Share Posted February 20, 2010 As long as your BL/BP ('05-'09) has a plastic gas pedal, it's an easy modification. A metal pedal will require more modification, but I'm pretty confident that if I were presented with that problem, I could still pretty easily make it fit. Plastic, FTW! Now there's a phrase you don't hear every day... Link to comment Share on other sites More sharing options...
D_J Posted February 20, 2010 Share Posted February 20, 2010 I really wish there was an STi dead pedal similar to the new style photo posted by OP. The only new style one I've seen is for JDM only. Link to comment Share on other sites More sharing options...
Warbaby Posted April 5, 2010 Share Posted April 5, 2010 I installed my STi A/T pedal set today on my 2006 Legacy GT using the recommendations provided by TSi+WRX. For the '05-06 models, you definitely need to notch and grind down the gas pedal in order for the "side wings" of the gas pedal cover to fit. It took a little bit of time and a lot of patience, but I got everything to fit okay after several test fittings. I was able to use the collar (part #12), but I'm not really sure what purpose it serves. Link to comment Share on other sites More sharing options...
DJ Doc Posted April 6, 2010 Share Posted April 6, 2010 I've had the new STi M/T pedal set on my 2007 2.5i for a little over a week and love it! Link to comment Share on other sites More sharing options...
Warbaby Posted April 16, 2010 Share Posted April 16, 2010 Here's what everything looked like with my Prosport dead pedal installed. http://members.shaw.ca/ababoneau/prosport1.jpg Link to comment Share on other sites More sharing options...
