Legasee Posted March 24, 2005 Share Posted March 24, 2005 I've searched and can't find..... I like the ride and am happy with the front and rear wheel gaps on my 05 GT...but I am looking for rims with the EXACT specs as the factory 05 GT's....I want to have the same ride as it has now. Can someone point me to some of the rims or give me the rim width and offset? Thanks so much! In Taiwan now... Link to comment Share on other sites More sharing options...
Xenonk Posted March 24, 2005 Share Posted March 24, 2005 see volk wheels or gram lights for OEM-like sizing and lighter weight, all other wheels will be light as or heavier than stock wheels. you can do 17x7 +48mm offset.. you can do 17x7.5 +45mm offset.. you can do 17x8 + 42mm offset.. Those are your common rim sizes. All those sizes can use 225/45/17 tires. Also, read the offsets and tires sticky I posted up. There are wheels out there. You do not need EXACT specs at GT rims.. a few mm difference in offset wont kill your ride quality, neither as the 225/45/17 vs the stock 215/45/17. Keefe Keefe Link to comment Share on other sites More sharing options...
Legasee Posted March 24, 2005 Author Share Posted March 24, 2005 see volk wheels or gram lights for OEM-like sizing and lighter weight, all other wheels will be light as or heavier than stock wheels. you can do 17x7 +48mm offset.. you can do 17x7.5 +45mm offset.. you can do 17x8 + 42mm offset.. Those are your common rim sizes. All those sizes can use 225/45/17 tires. Also, read the offsets and tires sticky I posted up. There are wheels out there. You do not need EXACT specs at GT rims.. a few mm difference in offset wont kill your ride quality, neither as the 225/45/17 vs the stock 215/45/17. Keefe Thank Keefe, Your sticky was really good!...it's just that I've had bad experiences with rubbing from my previous cars (not my previous WRX), wheel shops telling me it's ok and then my car rubs...so.... In Taiwan now... Link to comment Share on other sites More sharing options...
Legasee Posted March 24, 2005 Author Share Posted March 24, 2005 I'm diggin these... http://www.5zigenusa.com/images/wheels/pracer_gn_mattbrz2_600.jpg In Taiwan now... Link to comment Share on other sites More sharing options...
boostsr20 Posted March 24, 2005 Share Posted March 24, 2005 Stock is 17x7 +55. I believe. Link to comment Share on other sites More sharing options...
Legasee Posted March 24, 2005 Author Share Posted March 24, 2005 17 x 7.5 +48 5x100--fits Legacy, Impreza 2.5RS, WRX Wagon Very seriously considering these ....what do you guys think? Should fit fine In Taiwan now... Link to comment Share on other sites More sharing options...
Xenonk Posted March 24, 2005 Share Posted March 24, 2005 yea, they will fit perfectly fine. Keefe Keefe Link to comment Share on other sites More sharing options...
gtguy Posted March 25, 2005 Share Posted March 25, 2005 The exact spec will be difficult to find. Closest are the 17" UK Subaru wheels (the ones in the champagne gold color), or Prodrive P1s. Both, I believe, are +53 offset in the 17" size. Kevin Link to comment Share on other sites More sharing options...
Legasee Posted March 27, 2005 Author Share Posted March 27, 2005 diggin the Prodrive PFF7's in bright flitter http://www.prodrive.com/defaultflash.asp?M=6 for my silver GT!!! 18x8 for $1196 shipped at http://www.clubwrx.net/forums/showthread.php?t=97564 This is the best price that i've seen...anywhere cheaper?? In Taiwan now... Link to comment Share on other sites More sharing options...
Mach V Dan Posted April 4, 2005 Share Posted April 4, 2005 Factory wheel weighs 20.5 pounds, by the way. --DanMach VFastWRX.com Link to comment Share on other sites More sharing options...
