flander Posted October 28, 2009 Share Posted October 28, 2009 I had to replace my driver side headlight bulb, after getting a fix-it ticket, and I noticed the beam pattern seems little strange to me. It's like the driver side is aiming down. The car was parked about 7 feet from the door and the camera was about bulb height. Is the beam pattern correct or am I just going crazy? What does everybody think? I checked the bulb and it's in the socket correctly. Do I need to adjust the drivers side? http://lh5.ggpht.com/_b1dUyb4BLW8/SujPpU6HcUI/AAAAAAAAAgw/_BWLHQm0WLk/s800/beam%20pattern.JPG Link to comment Share on other sites More sharing options...
MiniStiGuy Posted October 29, 2009 Share Posted October 29, 2009 Thats a nice cutoff and spread but its totally crooked. I would make sure you have the bulb Flat in the socket and that it is the correct fitment as well. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
BalboaT4 Posted October 29, 2009 Share Posted October 29, 2009 This happened to me. The bulb was just upside down. Link to comment Share on other sites More sharing options...
DrSpeed Posted October 29, 2009 Share Posted October 29, 2009 How do you adjust the light aim? Are there screws? BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted October 29, 2009 Share Posted October 29, 2009 look under the exterior section for my "how to aim your headlights" it should be sticky'd up at the top. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
MiniStiGuy Posted October 29, 2009 Share Posted October 29, 2009 Yup its right up at the top. http://legacygt.com/forums/showthread.php?t=54740 OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
DrSpeed Posted October 29, 2009 Share Posted October 29, 2009 Yup its right up at the top. http://legacygt.com/forums/showthread.php?t=54740 you rock. BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
Polo08816 Posted October 29, 2009 Share Posted October 29, 2009 I don't think this is an "aim" issue. The pattern is really odd. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted October 29, 2009 Share Posted October 29, 2009 its not an aim issue. The guy just asked if there was an aiming guide so I pointed him to it. The OP's issue is a mismounted bulb or the wrong size bulb. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
flander Posted October 30, 2009 Author Share Posted October 30, 2009 Would it be the left side is correct and the right side is up-side down? The right side seems brighter. I haven't checked the right side bulb. I know the left side is in there correctly. I checked it when I took the picture. Link to comment Share on other sites More sharing options...
lilbrudder Posted October 30, 2009 Share Posted October 30, 2009 Are they OEM bulbs? It's not an aim issue, there is an angle wrong somewhere...maybe the bulb frame? Switch the bulb to the other light and it will tell you if it is them (bulbs) or something in the projector housing. Link to comment Share on other sites More sharing options...
flander Posted October 30, 2009 Author Share Posted October 30, 2009 No, there are not OEM bulbs. Not sure what brand bulbs there are but they only cost me $10 each. I know they are inexpensive but I had to since I'm broke. I would like to get some HID for it but that's going to be a while. I'll try switching bulbs to see if it is the bulbs thats doing it. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted October 30, 2009 Share Posted October 30, 2009 your passenger one is fine. your driver bulb is wrong though. make sure the bulb is a H7 and better yet take it out and take a pic for us. Make sure the bulb is flat as well, some aftermarket makers may not seem to go in more but they do go in more and flatten out. They make the bases to wide sometimes so you'll have to sand the edge of the base a little to get it enough space to push all the way in and go flat. Take pics of the bulb in the headlamp and take a pic of the bulb out. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
flander Posted October 31, 2009 Author Share Posted October 31, 2009 Well, I found the problem. I had the driver side in wrong. Thats what I get for installing it at 12:30am. Link to comment Share on other sites More sharing options...
