smoker Posted October 23, 2009 Share Posted October 23, 2009 Preparing to do a front and rear brake line swap to SS on an 06 OBXT. Need to buy a good set of brake line wrenches so, I can remove the OEM flex/rubber line(from the caliper) from the main line. What size wrenches are needed for the main and flex/rubber line? p.s. did search but only found the size for the bleeder on the caliper 10MM. Link to comment Share on other sites More sharing options...
maxjlone Posted October 24, 2009 Share Posted October 24, 2009 Most of the fittings are 11mm. I could never find an 11mm flare wrench but a 7/16" is close enough and works fine. ____________________ Are You Paying More Auto Insurance Than Your Neighbour? Click Here And Save! Link to comment Share on other sites More sharing options...
magnetic1 Posted October 24, 2009 Share Posted October 24, 2009 Most of the fittings are 11mm. I could never find an 11mm flare wrench but a 7/16" is close enough and works fine. ____________________ Anchor - Are You Paying More Auto Insurance Than Your Neighbour? Click Here And Save! You can find 11mm flares all over the internet. Should be under $10 and would be advised instead of a 7/16". You run a high risk of stripping a bolt and that will not be fun to replace... Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
smoker Posted October 26, 2009 Author Share Posted October 26, 2009 Thanks Guys. I picked up a flare set at sears. Link to comment Share on other sites More sharing options...
