ssabat Posted October 20, 2009 Share Posted October 20, 2009 Every time I pull a U-Turn ( a quick one ), I get thuds in the steering as it goes from full turned back to straight?.. Could it be low tire pressure? Tires in general? Power steering problems? Help! Current Mileage 55,192... Link to comment Share on other sites More sharing options...
speddmn Posted October 20, 2009 Share Posted October 20, 2009 balljoint Link to comment Share on other sites More sharing options...
ehsnils Posted October 20, 2009 Share Posted October 20, 2009 Center diff doing it's work too. Do slower U turns. Link to comment Share on other sites More sharing options...
ssabat Posted October 20, 2009 Author Share Posted October 20, 2009 Do I need to replace anything? Would you conisder the balljoint/center diff a wear-tear item. I have a full coverage warranty that expires in 4 years Link to comment Share on other sites More sharing options...
E-Tank Posted October 20, 2009 Share Posted October 20, 2009 I have same mileage and same issue, but also with a high pitched whine. only when turning very sharp and going up-hill. Link to comment Share on other sites More sharing options...
ssabat Posted October 20, 2009 Author Share Posted October 20, 2009 I dont get the whine when I turn but I definately get it as I accelerate. Thank the lord for LGT gear whine haha.. 1-2 definately, once I engage into third it disappears Link to comment Share on other sites More sharing options...
Mendozer Posted October 21, 2009 Share Posted October 21, 2009 I dont get the whine when I turn but I definately get it as I accelerate. Thank the lord for LGT gear whine haha.. 1-2 definately, once I engage into third it disappears Now I know that Subaru's are symetric awd but does this not sound like it could possibly be a axle/CV issue? Link to comment Share on other sites More sharing options...
PhilT Posted October 21, 2009 Share Posted October 21, 2009 Center diff doing it's work too. Do slower U turns. Centre Diff should never make clunking noises Seems to be a ball joint issue, get it looked at. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Dan007CT Posted October 21, 2009 Share Posted October 21, 2009 my moms Forester has done this from day 1 on sharp turns. She also eventually had the whine which I think was fixed by changing the power steering belt. it wasnt a screech.. it was a whine. OR the whine was because it was REALLY cold and I think the fluid can thicken up? It doesnt do it in the summer or warmer months.. the whine. The other u-turn thing it still does. lol Link to comment Share on other sites More sharing options...
oddseth Posted October 21, 2009 Share Posted October 21, 2009 Also check your power steering fluid reservoir. I remember one time hearing a humming coming from my car whenI had the steering wheel all of the way over at low speeds. My father recommended that I check my steering fluid and when I checked, it was below the 'low' mark. After adding some fluid, everything was good. Link to comment Share on other sites More sharing options...
ssabat Posted October 21, 2009 Author Share Posted October 21, 2009 thanks guys , i really appreciate it. I'm going to get it looked at on Friday. I should ask them to inspect my balljoint...anything else? how long does this repair take? I have a bumper to bumper warranty.. I hope it gets covered! Link to comment Share on other sites More sharing options...
ssabat Posted October 21, 2009 Author Share Posted October 21, 2009 Also check your power steering fluid reservoir. I remember one time hearing a humming coming from my car whenI had the steering wheel all of the way over at low speeds. My father recommended that I check my steering fluid and when I checked, it was below the 'low' mark. After adding some fluid, everything was good. my reservoir is topped off, I also had loose belts and got that all tightened. Maybe the cold weather is playing a trick on my leggy. Now when i do cold starts, my car screeches =/ it's happend twice. Link to comment Share on other sites More sharing options...
RJS5689 Posted October 22, 2009 Share Posted October 22, 2009 my reservoir is topped off, I also had loose belts and got that all tightened. Maybe the cold weather is playing a trick on my leggy. Now when i do cold starts, my car screeches =/ it's happend twice. Happens to me during the winter months too. Usually not until we get to the negative temps though. Link to comment Share on other sites More sharing options...
