jdmblock Posted October 17, 2009 Share Posted October 17, 2009 I have a 97 legacy gt 2.5 today I was letting it warm up I went outside and it sounded like it was having trouble getting air through the intake. i turned it of then tried to restart the car. The car would turn on and then struggle for air and die down. I was thinking it could be the mass air flow sensor any ideas Link to comment Share on other sites More sharing options...
petegc Posted October 17, 2009 Share Posted October 17, 2009 try disconnecting the electrical connector on the air mass meter when the car starts and if it run's smoother it very means a new air mass meter is needed (though always but very often) i need one but £323.16p from main dealer !!! OUCH , better off to be sure to find a garage with plug in diagonostics on a laptop etc , in bristol this is only £35 for 30mins , and it stops all the guess work too , which get very very time consuming and expensive if you start buying unneccasary sensors as most parts suppliers will not allow return of electical parts unless faulty etc. cheers Pete Link to comment Share on other sites More sharing options...
kaz98gt Posted October 18, 2009 Share Posted October 18, 2009 if it's not electrical or anything, check the snorkle routed through the fender, the airbox itself, the filter, or the torque box toward the throttle body for any signs of wear or obstructions. i know it's a stupid question, but did you check the filter? haha if you can find the plug in diagnostics (OBD hook-up under the dash to the left of the steering wheel) at a shop or if you have the equiptment, that will give you a good reading of what might be the problem electrically. Link to comment Share on other sites More sharing options...
one bad bg Posted October 19, 2009 Share Posted October 19, 2009 i got a maf sensor off a subie at the jnkyard for 20 bucks and it works perfect Link to comment Share on other sites More sharing options...
