gpbakken Posted October 9, 2009 Share Posted October 9, 2009 I've been having some odd electrical issues with my 1998 Legacy Outback. on a seemingly random basis, all electrics will simply go "dead". that being said, the car will "come alive" again, if the driver's door area is jarred hard enough, usually slamming the driver's door will be enough, although occasionally a much lighter jolt will do. the clock on the radio resets to 12:00 when this happens. the connection to the battery is solid, and the terminals clean. the battery and alternator are about a year old. plug wires and plugs are brand new, starter is also about a year old. Also, at times the electrical seems weak, this is manifested by the following situations- with the headlamps and foglamps on, depressing the brake will momentarily cause the headlamps and foglamps to flicker off and on again, nothing more than a fraction of a second worth of a flash. Idle speed tends to be about 600 to 650 rpm. however, this on rare occasion will drop to maybe 400 for a moment and then spring back up, to 700-800 then settle back to about 650. Can anyone offer any advise or suggestions? Many thanks in advance. Grant Link to comment Share on other sites More sharing options...
one bad bg Posted October 13, 2009 Share Posted October 13, 2009 buy a grounding kit for your battery. their only about 50 bucks online Link to comment Share on other sites More sharing options...
eekay Posted October 14, 2009 Share Posted October 14, 2009 Wow. What an incredibly strange problem... I can't wait to find out what's causing this. My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
Platinum_Racing Posted October 14, 2009 Share Posted October 14, 2009 +1 for the ground. Just run another wire from the negative terminal on the battery to any place you fin put a bolt through. Make sure it's a good ground though, paint will prevent electricity from flowing. Link to comment Share on other sites More sharing options...
pillboy Posted October 14, 2009 Share Posted October 14, 2009 Everybody checks the cables at the battery...there is another end to those cables. Check those. It is still ugly. Link to comment Share on other sites More sharing options...
gpbakken Posted October 15, 2009 Author Share Posted October 15, 2009 eekay -*laugh* yeah, I've never been one to do things half-way. onebad, platinum, pillboy- I'll check for ground cable issues- I suppose that'd sap enough voltage to make it appear that the alternator's weak too perhaps? Platinum, how heavy would you recommend the copper to be for running another ground to chassis? I'd hate to see something burn up because I'm being cheap. thanks again to all of you! Link to comment Share on other sites More sharing options...
one bad bg Posted October 18, 2009 Share Posted October 18, 2009 i dont have ground cable issues haha oh wait i read the thread wrong sorry. i forgot you were the one who posted this Link to comment Share on other sites More sharing options...
