F1nALMSFan Posted October 6, 2009 Share Posted October 6, 2009 Hello, I just got my AP this afternoon and while it will recognize my car as 08-09 LGT Specb, when I try to load any map I get a comm error. I have tried unhooking the cable numerous times, same thing, error message. Any ideas? Thanks a lot for any help. I look forward to going to stage 1 . Kevin Link to comment Share on other sites More sharing options...
PGT Posted October 6, 2009 Share Posted October 6, 2009 new car to you or new AP? Link to comment Share on other sites More sharing options...
Ssej Posted October 6, 2009 Share Posted October 6, 2009 I believe you need to put your car into test mode by connecting the green connectors on the passenger footwell. Did you do that? Link to comment Share on other sites More sharing options...
F1nALMSFan Posted October 6, 2009 Author Share Posted October 6, 2009 New AP and new car. Link to comment Share on other sites More sharing options...
F1nALMSFan Posted October 6, 2009 Author Share Posted October 6, 2009 Tried with and without green connectors, still recieved the Comm error. Link to comment Share on other sites More sharing options...
Ssej Posted October 6, 2009 Share Posted October 6, 2009 You need to have it in test mode while you are loading the map, and the key should be in the ON position. Do you have the AP-SUB-002 or AP-SUB-003? I'm pretty sure you need the 003 for that year SpecB. Link to comment Share on other sites More sharing options...
F1nALMSFan Posted October 6, 2009 Author Share Posted October 6, 2009 Yep, have the AP-Sub-003 and the car was in test mode (green connectors plugged in) car was in "on" engine not started. Still get Comm errors under those settings. Thanks for the responses. Link to comment Share on other sites More sharing options...
Bulletproof4age Posted October 6, 2009 Share Posted October 6, 2009 I don't put mine in test mode. I think all 07+ don't need it. Link to comment Share on other sites More sharing options...
F1nALMSFan Posted October 6, 2009 Author Share Posted October 6, 2009 Right, the 07+ do not need to be in test mode to transfer maps. I have tried with and without connecting the green connectors. Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted October 6, 2009 Share Posted October 6, 2009 I had some comm errors too when i just reflashed. I just had to turn the key on n off a few times.. (not starting it)... Link to comment Share on other sites More sharing options...
F1nALMSFan Posted October 8, 2009 Author Share Posted October 8, 2009 This was Cobbs suggestion too, however after 30 min of key off and on, still no such luck. Link to comment Share on other sites More sharing options...
TPLGT Posted October 8, 2009 Share Posted October 8, 2009 In for solution...and pics of NSX! Rehab is for quitters. Link to comment Share on other sites More sharing options...
tommypenguin Posted October 8, 2009 Share Posted October 8, 2009 Might sound like an obvious suggestion but have you tried holding the AP bung into the OBD-II port, ie holding/pushing it in firmly while the AP is trying to communicate? I've read of a couple of members before who couldn't get the AP to communicate to the car because the plug wasn't in snug enough. Never know might be lucky, test connectors will need to be connected for you to communicate since you haven't gotten to marry your ap to your ecu. Good luck. Link to comment Share on other sites More sharing options...
F1nALMSFan Posted October 9, 2009 Author Share Posted October 9, 2009 Well after talking with Cobb for the past two days they think it may be a problem with the AP although they did acknowledge that this problem has happened before. I am sending it back to them tomorrow and hopefully will get a working one sent back. Link to comment Share on other sites More sharing options...
F1nALMSFan Posted October 12, 2009 Author Share Posted October 12, 2009 Update: Talked to Cobb today, it appears that the AP I recieved had a loose electrical wire which was the cause of my errors. They are sending me a new one today. I must say, I have read about people having problems with Cobb service, but I having nothing but good things to say about them. They have been very helpful and responsive to my problem. Other than sending me a broken AP of course Link to comment Share on other sites More sharing options...
