tedsan126 Posted September 29, 2009 Share Posted September 29, 2009 I was thinkin of putting this programmer into my 98' legacy ej22. Does anyone have any opinions or expieriences with it http://www.titanmotorsports.com/afcneo.html Link to comment Share on other sites More sharing options...
Platinum_Racing Posted September 30, 2009 Share Posted September 30, 2009 Without a VTEC Honda engine, all it's gonna do is mess up the ideal 14.7:1 air fuel ratio maintained by the ECU. There are cheaper alternatives that don't have the adjustable VTEC engagement point that you're never going to use anyway. Link to comment Share on other sites More sharing options...
05lgt5spd Posted September 30, 2009 Share Posted September 30, 2009 It not designed specifically for Vtec, it just has that feature. All you can really do with that is adjust your fuel mixture, and its not going to give you any feedback, so your more likely to toast your motor with it. Link to comment Share on other sites More sharing options...
gathermewool Posted September 30, 2009 Share Posted September 30, 2009 But, it has a virbant screen! ; ) '15 FB25 Magnatec 0W-20 + FU filter (70,517 miles) RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where Link to comment Share on other sites More sharing options...
Platinum_Racing Posted October 1, 2009 Share Posted October 1, 2009 It not designed specifically for Vtec, it just has that feature. All you can really do with that is adjust your fuel mixture, and its not going to give you any feedback, so your more likely to toast your motor with it. Exactly. This will work with the car, but the only 2 features it has are for fuel mixture adjustments and VTEC engagement adjustments. He could buy a fuel mixture adjustment programmer without the VTEC feature for cheaper, but then he would still be overriding the ECU in it's attempts to maintain an ideal 14.7 : 1 air fuel ratio. This device could run the engine too rich or too lean very easily, fouling spark plugs left and right. Link to comment Share on other sites More sharing options...
