jakesterNZ Posted September 20, 2009 Share Posted September 20, 2009 New Subaru owner here. Just purchased a 2000 RSK Legacy Blitzen in red! All is going well so far apart from my "Trunk Open" indicator staying lit. Obviously the trunk is closed. The light will sometimes go out, but then come back on again. Is there a swicth i should be checking for cleaning? Just wondering if someone else has had this issue. Any help solving this issue would be appreciated! Link to comment Share on other sites More sharing options...
Platinum_Racing Posted September 20, 2009 Share Posted September 20, 2009 If by boot you mean "Trunk" then I cannot comment, other than to politely notify you that most people on here are American, and that crazy British talk confuses our feble minds. Anyway, I cannot comment as I don't own that generation Legacy, but I will kindly ask you to add the model and trim level of your car to your profile, as it will make things easier in the future. From experience from other cars, check the switch near the trunk (Boot) and the wires that lead to it. If you can't find anything wrong, replace the switch. If that doesn't work, remove the light in the dashboard. And welcome to the forum! It's pretty fun here, but it can be overly-dramatic at times... Link to comment Share on other sites More sharing options...
quicklook2 Posted September 20, 2009 Share Posted September 20, 2009 the switch sounds bad. pretty easy to find and tighten or replace. Link to comment Share on other sites More sharing options...
big ears Posted September 20, 2009 Share Posted September 20, 2009 The bloke appears to be located in beautiful New Zealand where the trunk is definetely called the Boot. Link to comment Share on other sites More sharing options...
jakesterNZ Posted September 21, 2009 Author Share Posted September 21, 2009 beautiful NZ indeed! It looks like the cd stacker has been removed at some stage (maybe on import from Japan) as there are a few hanging wires taped to the interior part of the "trunk" the trunk light is also not working. Have replaced the bulb. Fuse issues maybe? Link to comment Share on other sites More sharing options...
