jabronee Posted September 19, 2009 Share Posted September 19, 2009 Do rotors just pop off? or is there a special tool needed to remove rotors? Link to comment Share on other sites More sharing options...
Waxiboy Posted September 19, 2009 Share Posted September 19, 2009 There is a special tool needed.... M8 bolt that you screw into 2 holes in the rotor so that it will push the rotor out from the hub I just use the one that holds the radiator in place. Link to comment Share on other sites More sharing options...
Regal05LGT Posted September 20, 2009 Share Posted September 20, 2009 Yea, took me quite some time to figure that out when I did my rotors.....sledge hammer didn't work so I did some research and realized you needed a bolt lol....get a 8mm bolt (pretty sure that's the size) they pop right off Link to comment Share on other sites More sharing options...
