Kipper Posted September 18, 2009 Share Posted September 18, 2009 The mechanic that did my timing belt three years ago, stripped the threads in the housing for the timing belt tensioner!! The bolt is in good shape but the threads in the housing are messed up. Whats a good fix for reparing these threads???? Link to comment Share on other sites More sharing options...
Platinum_Racing Posted September 19, 2009 Share Posted September 19, 2009 Get a metric tap and die set and see if you can re-thread the existing threads. If you don't have access to a metric tap and die set, take one of the old bolts and set it on a table standing straight up and down, standing on the head of the bolt.. With a Dremel tool or an air grinder with a cutoff wheel, put a slot in the screw, from top to bottom, right up the threads. Now, reinstall the bolt and it should cut new threads. It's a good idea to get a new bolt after this. If the threads don't take well to being re-tapped with the slotted bolt trick, drill the hole out with a metric drill bit one size larger than the last one, get a metric tap and die set, and re-thread the new hole, making it one size larger than it was before. When it's all done, get yourself a new bolt that corresponds to the thread type and size of the hole you tapped out. Be careful though, this can be tricky. It's best to go slow and take your time. Link to comment Share on other sites More sharing options...
Kipper Posted September 19, 2009 Author Share Posted September 19, 2009 Thanks for the advice! Ill try that. This is getting old because I live above a resturant and I am doing all this stuff out in the parking lot. I have 272K on this car and I just want it to last one winter, up here in VT. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted September 19, 2009 Share Posted September 19, 2009 Drive it till the wheels fall off, that's what I plan on doing with mine... Link to comment Share on other sites More sharing options...
jamal Posted September 19, 2009 Share Posted September 19, 2009 Not sure I would trust re-threading that. Find another bracket somewhere or install a helicoil. Link to comment Share on other sites More sharing options...
DN1911 Posted September 20, 2009 Share Posted September 20, 2009 i would use a heli-coil or the one i prefer the most, a Keysert http://www.newmantools.com/key.htm. they are usually available at most specialty hardware stores Link to comment Share on other sites More sharing options...
