25gtrbo Posted September 10, 2009 Share Posted September 10, 2009 So i finally got the bug and went stage 1.. Wow what a difference compared to stock on a 5eat.. The only concern i had was the slight hesistation, studdering and throttle response which i thought was going to be fixed by a new map.. Today on my way to work im cruising around 50 and i decide that i want to go a little faster.. I push the pedal a little more and nothing happens.. Im not going any faster and the rpms are staying a constant 2000 rpms. I give her more gas and then shes balls to the wall. What gives.. is there a problem with the map?? Im wondering if i should run the identical base map in realtime as well. When i bought the used apv1 it came with a tdc stage 1 tune for the same car i have. Is this map something i should try or just get rid of it due to it possibly being personalized to someone elses car Link to comment Share on other sites More sharing options...
05pearl Posted September 10, 2009 Share Posted September 10, 2009 http://legacygt.com/forums/showthread.php?t=103997 Link to comment Share on other sites More sharing options...
pattypat Posted September 10, 2009 Share Posted September 10, 2009 You should try it definatly. It might be just a OTS map that's not real specific to your car. You should feel a difference from the cobb map. Link to comment Share on other sites More sharing options...
Infamous1 Posted September 10, 2009 Share Posted September 10, 2009 When i bought the used apv1 it came with a tdc stage 1 tune for the same car i have. Is this map something i should try or just get rid of it due to it possibly being personalized to someone elses car FWIW just search the site under "TDC" and make your own decision. That being said a typical stg 1 tune is only so wild. Link to comment Share on other sites More sharing options...
pattypat Posted September 10, 2009 Share Posted September 10, 2009 I wish I would have done my research more before I bought my AP last week. I wasn't up to date with this OS tuning that Infamous does. Even though I got real good deal on the APv2 I realize that open source was probably the way to go. I'm happy with my map that I have it's a Tuning Alliance(Mike Kinsmen used to run TDC) stage 1 for Kn panel, Perrin CBE. It's a little more specific. But that's what I have for now. I will definalty consider using open source for Stage2. That being said I would go with the OS tuning If I had to do it again... Link to comment Share on other sites More sharing options...
25gtrbo Posted September 10, 2009 Author Share Posted September 10, 2009 I may try the stage 1 tune by tdc but Im not sure if it is safe or not to use see how it came from someone else Link to comment Share on other sites More sharing options...
MiniStiGuy Posted September 10, 2009 Share Posted September 10, 2009 just about any stage 1 tune will be fine. I ran TDC stage 1 and 2 and both were fine. My stage 1 all I had was an exhaust and it ran fine. I liked the TDC over the cobb because it felt much better. Here's my Dyno for my TDC stage 1. http://i170.photobucket.com/albums/u280/garrett804/dyno7-21-07.jpg OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
