Garrett-21 Posted September 28, 2009 Share Posted September 28, 2009 Is a SRI better for the engine than a CAI?? problem wise?? CAI can sometimes pic up water and snow. stuff like that but all you need is a sheild.. Link to comment Share on other sites More sharing options...
lufergupdown Posted September 28, 2009 Share Posted September 28, 2009 I live in Maine.... so snow will be a problem... but if i get a shield it will be fine. I've heard a lot about the air flow sensor messing up with CAI.... is there anyway to get around that.. or is that just a luck thing? Link to comment Share on other sites More sharing options...
Lagbot Posted September 28, 2009 Share Posted September 28, 2009 I live in Maine.... so snow will be a problem... but if i get a shield it will be fine. I've heard a lot about the air flow sensor messing up with CAI.... is there anyway to get around that.. or is that just a luck thing? this is just my .02$ i talked to a mechanic when i was getting a intake on my car and from what he said as long as there is no air leaks or anything like that you will be fine. like i said just my .02$ Link to comment Share on other sites More sharing options...
lufergupdown Posted September 28, 2009 Share Posted September 28, 2009 well that's good to know... thanks for the info Link to comment Share on other sites More sharing options...
ronnieb55 Posted September 29, 2009 Share Posted September 29, 2009 well after about 100 miles the cosmo intake did set a cel so i'm not sure what i'm going to do. question to all the cosmo intake owners. did you remove the silcone reducer right before the sensor? Link to comment Share on other sites More sharing options...
socallegacy Posted September 29, 2009 Share Posted September 29, 2009 well after about 100 miles the cosmo intake did set a cel so i'm not sure what i'm going to do. question to all the cosmo intake owners. did you remove the silcone reducer right before the sensor? i didnt. i had about 10-15 cel then it just stoped Link to comment Share on other sites More sharing options...
ronnieb55 Posted September 29, 2009 Share Posted September 29, 2009 i went out and bought a can bus obd2 reader and deleted it Link to comment Share on other sites More sharing options...
lufergupdown Posted September 29, 2009 Share Posted September 29, 2009 I'm not sure what that means but I was thinking about getting the cosmo cold air intake.. Is it worth it?? Link to comment Share on other sites More sharing options...
socallegacy Posted September 30, 2009 Share Posted September 30, 2009 I'm not sure what that means but I was thinking about getting the cosmo cold air intake.. Is it worth it?? i have the cai and love it in the higher rpms it sounds very nice. and what he meant was a code readers Link to comment Share on other sites More sharing options...
lufergupdown Posted September 30, 2009 Share Posted September 30, 2009 That's good to know you like the cai. i'm pretty sure i'm going to purchase it sometime soon. Link to comment Share on other sites More sharing options...
socallegacy Posted September 30, 2009 Share Posted September 30, 2009 That's good to know you like the cai. i'm pretty sure i'm going to purchase it sometime soon. you what what to check into a Throttle Body spacer it help with the lost torque this is the one a lote of us run http://www.groupa.ca/PR_throttle_body_spacer.html Link to comment Share on other sites More sharing options...
lufergupdown Posted September 30, 2009 Share Posted September 30, 2009 Does that throttle body space get installed with the cia? Link to comment Share on other sites More sharing options...
socallegacy Posted September 30, 2009 Share Posted September 30, 2009 Does that throttle body space get installed with the cia? it go's between the throttle body and the intake manifold it helps a lote Link to comment Share on other sites More sharing options...
lufergupdown Posted September 30, 2009 Share Posted September 30, 2009 Is the throttle body that big black thing at the back of the engine? because with the cosmo air intake... that gets removed sorry about all the questions too... i'm new with all of this stuff. Link to comment Share on other sites More sharing options...
socallegacy Posted September 30, 2009 Share Posted September 30, 2009 Is the throttle body that big black thing at the back of the engine? because with the cosmo air intake... that gets removed sorry about all the questions too... i'm new with all of this stuff. yes the big black box go's away with the new in take Link to comment Share on other sites More sharing options...
lufergupdown Posted October 1, 2009 Share Posted October 1, 2009 So if that box is the throttle body.. what does the throttle body spacer do if there is no throttle body after the air intake is in? Link to comment Share on other sites More sharing options...
koneheff Posted October 1, 2009 Share Posted October 1, 2009 the big black box isn't the throttle body.....the throttle body is what that is attached to. Link to comment Share on other sites More sharing options...
socallegacy Posted October 1, 2009 Share Posted October 1, 2009 the big black box isn't the throttle body.....the throttle body is what that is attached to. yes Link to comment Share on other sites More sharing options...
Sumbex Posted October 1, 2009 Author Share Posted October 1, 2009 Has anyone installed underdrive pulleys? Supposedly you can get about 5-10 hp from these aftermarket pulleys. Is it a overestimate of gains or will this actually increase performance? Link to comment Share on other sites More sharing options...
apexi Posted October 1, 2009 Share Posted October 1, 2009 If you're looking to increase power, pulleys and cai on a 2.5i are a huge waste of money, it won't do anything. Link to comment Share on other sites More sharing options...
WheelsOfGlue Posted October 1, 2009 Share Posted October 1, 2009 Nice work Garrett-21 Keep us all posted on any performance issues that might arise. Link to comment Share on other sites More sharing options...
Garrett-21 Posted October 1, 2009 Share Posted October 1, 2009 http://i79.photobucket.com/albums/j156/garrett-21/DSCN0243.jpg http://i79.photobucket.com/albums/j156/garrett-21/DSCN0238.jpg http://i79.photobucket.com/albums/j156/garrett-21/DSCN0239.jpg http://i79.photobucket.com/albums/j156/garrett-21/DSCN0240.jpg http://i79.photobucket.com/albums/j156/garrett-21/DSCN0241.jpg http://i79.photobucket.com/albums/j156/garrett-21/DSCN0242.jpg Link to comment Share on other sites More sharing options...
lufergupdown Posted October 1, 2009 Share Posted October 1, 2009 Sick car!!!!! Link to comment Share on other sites More sharing options...
socallegacy Posted October 1, 2009 Share Posted October 1, 2009 If you're looking to increase power, pulleys and cai on a 2.5i are a huge waste of money, it won't do anything. it help my car. my car felt slow and sluges did the pulley kit with cai and tb spacer and its a hole new car Link to comment Share on other sites More sharing options...
socallegacy Posted October 1, 2009 Share Posted October 1, 2009 http://i79.photobucket.com/albums/j156/garrett-21/DSCN0243.jpg http://i79.photobucket.com/albums/j156/garrett-21/DSCN0238.jpg http://i79.photobucket.com/albums/j156/garrett-21/DSCN0239.jpg http://i79.photobucket.com/albums/j156/garrett-21/DSCN0240.jpg http://i79.photobucket.com/albums/j156/garrett-21/DSCN0241.jpg http://i79.photobucket.com/albums/j156/garrett-21/DSCN0242.jpg very nice just needs to be lower Link to comment Share on other sites More sharing options...
