97, 2.2L wagon, click sound appears
xiaomanbluce
Could be a wheel bearing. Mine had a slight clicking when I was driving but it went away. If it is a louder, more violent click it could be a CV shaft. If it does it more under hard acceleration or while turning in one direction it's probably a CV shaft. It could also be a rusted rotor shield that's vibrating and hitting the rotor, which just involves bending the shield away from the rotor.
I'd lift whe wheel off the ground and try seeing if there's any play in the wheels. Grab the CV shaft and see if there is any play in those as well. Try bending the rotor shield away and see if it goes away. If you still have a problem post back and we'll try something else.
