05GT Guru Posted September 8, 2009 Share Posted September 8, 2009 Here an E46 M3 is a low 14-second car. I've seen a couple scratch into the 13's @ 101-102mph. My Stage I LGT running E85 ran 13.6's@99mph. I haven't made it back out to the track since the addition of new UP and DP, but based on MAF, road dyno numbers etc. I would guess that my car is likely capable of low 13's now. Nonetheless, even at sea level, a stage II LGT should be a good match for a stock E46 M3. I don't know why anyone would think that an E46 M3 would decimate the stage II LGT in a straight line. Just because it is a ZOMG M doesn't mean it's a straight-line demon. These cars were meant for turns, not stoplight show downs. Never did I say it would decimate, I said they run mid 13s and thats about what a stage 2 legacy is. Some have gone faster yes. I used to drag race alot and loved racing m3s in a straight line, just not so much through turns. Link to comment Share on other sites More sharing options...
biz77 Posted September 8, 2009 Share Posted September 8, 2009 Never did I say it would decimate, I said they run mid 13s and thats about what a stage 2 legacy is. Some have gone faster yes. I used to drag race alot and loved racing m3s in a straight line, just not so much through turns. And I never said YOU did;) Somebody did... Nope. You'd get raped. The E46 M3 is not a car to be trifled with lightly, it will easily out handle a modded LGT and at any speed over 50mph will simply leave you in the dust even at stage 2. Link to comment Share on other sites More sharing options...
05GT Guru Posted September 8, 2009 Share Posted September 8, 2009 And I never said YOU did;) Somebody did... It will be a easier race for the m3 at 50mph+ even at your higher alt the N/A car trapped higher than your FI car. N/A is effected more at higher alt and still out trapped your turbo car. So at sea level that legacy better hit 105-107mph to keep up/beat a m3 from a roll. vf40/46 powered cars trap around 103mph mostly, hell even some vf52 with bigger injectors only hit 105mph mark. Link to comment Share on other sites More sharing options...
