johnnymack Posted August 29, 2009 Share Posted August 29, 2009 EcuFlash is unable to read my ECU. The car has some sort of tune on it. I can log data but I can't flash anything. Yes, the diagnostic cables were connected correctly. Yes the cable and EcuFlash work, we hooked everything up to my buddy's WRX and it read his ECU. Basically, I'm locked out of my ECU by the previous tuner I believe. I have no way to find out what program the car was tuned with. The dealership was unable to read the ECU as well and said, "Its been tampered with". Car runs fine. Here's my other thread: http://www.legacygt.com/forums/showthread.php?t=117688 I need help! Link to comment Share on other sites More sharing options...
LGT Dave Posted August 29, 2009 Share Posted August 29, 2009 My guess would be that it had a Cobb Accessport installed on it and it was never unmarried before the car was traded in/sold. If that's the case, I think the only way to fix it is to take out the ECU and ship it to Cobb for them to reset. You should probably contact Cobb and ask them if there's any way for you to tell if it has an AP married to it or not. Link to comment Share on other sites More sharing options...
Spec B Posted August 29, 2009 Share Posted August 29, 2009 I was able to read my friend's STI tuned map while the AP was still married. I think this is a case of a protuner locking down his map completetly. Link to comment Share on other sites More sharing options...
LGT Dave Posted August 29, 2009 Share Posted August 29, 2009 It used to work, but sometime last year Cobb updated the v2 AP and made it so even the OTS maps can't be read using ECUFlash. Link to comment Share on other sites More sharing options...
Spec B Posted August 29, 2009 Share Posted August 29, 2009 ahhh..my buddy had AP v1. Link to comment Share on other sites More sharing options...
johnnymack Posted September 3, 2009 Author Share Posted September 3, 2009 Problem was solved: We took an AP V2 from a friends LGT, unmarried it from his car. We married the AP to my Spec B. AP read "Program Detected. Override? Yes." We installed the new AP, married it, then unmarried it. I now have my stock ECU back. Someone had traded the car in with an AP still married to the car. Worst part was that it was in "fuel conserv." mode. Now boost is higher, wastegate duty cycles are back and I'm a happy camper again. Link to comment Share on other sites More sharing options...
