ericb49 Posted March 16, 2005 Share Posted March 16, 2005 Nice Eric! Can I come see too? Certainly. I want to ride in your car and Merv's so I can get an idea of what I want to with the suspension. Althought...if I get the Tien then I can always adjust the ride from the cabin...hhmmmm They're Mangosteens Link to comment Share on other sites More sharing options...
Xenonk Posted March 16, 2005 Share Posted March 16, 2005 Certainly. I want to ride in your car and Merv's so I can get an idea of what I want to with the suspension. Althought...if I get the Tien then I can always adjust the ride from the cabin...hhmmmm Ride quality, not ride height.. which should be appropriate between the two.. the lower you ride, the stiffer you want your shocks.. or you end up blowing them out.. Just remember that. Keefe Keefe Link to comment Share on other sites More sharing options...
yukonm Posted March 17, 2005 Share Posted March 17, 2005 Turn that sway bar up more! It shouldnt be angled like that. You're very close of hitting the CV boot. Keefe "It shouldnt be angled like that. " - right. Owners of the 21mm Cusco rear bar may want to check if their endlinks are angled under rear wheel compression. (park car with diagonal wheels on blocks and inspect). I'm not sure adjustable endlinks will completely fix the issue - perhaps the bar's arms are slightly longer than the stock ones. Link to comment Share on other sites More sharing options...
Xenonk Posted March 17, 2005 Share Posted March 17, 2005 you just need to turn the swaybar up so that that the end link is facing towards the control arm, not away from it as you have shown. Keefe Keefe Link to comment Share on other sites More sharing options...
yukonm Posted March 17, 2005 Share Posted March 17, 2005 you just need to turn the swaybar up so that that the end link is facing towards the control arm, not away from it as you have shown. Keefe Are you saying the swaybar is upside down? Even if that were possible, the distance from the frame pivot to the end-link would be the same (potentially too long). http://pg.photos.yahoo.com/ph/yukonm/detail?.dir=cd50&.dnm=d94b.jpg&.src=ph discussion continued here: 'Cusco 21mm rear bar - install problem?' http://legacygt.com/forums/showthread.php?t=10029 Link to comment Share on other sites More sharing options...
