black318i Posted August 9, 2009 Share Posted August 9, 2009 I installed a 1mm pill and I think I have it dialed in now. Any suggestions for fine tuning boost or anything else on my tune. MAF g/s seems a bit low. I forgot to log intake temp, but it was about mid-upper 90's today and atmospheric pressure here is 14.65. Here is a 3rd gear run. I'll get a more complete log probably tomorrow. CA91 1mm pill Perrin TMIC AVO Ceramic cat DP OEM Cattles UP GFB BOV full recirc. http://www.box.net/shared/vivseumildWOT.csv Link to comment Share on other sites More sharing options...
black318i Posted August 11, 2009 Author Share Posted August 11, 2009 3rd gear20090809_160727.csv Link to comment Share on other sites More sharing options...
yamie700 Posted August 11, 2009 Share Posted August 11, 2009 You had a little knock at 5500rpm, do you always see it there or was it a one time thing? Might want to take some timing out there. Also, you don't need to log A/F Sensor #1 (AFR) its useless for WOT. And start your pull at 2000rpm, not 3000. I'll let the other more knowledgeable tuners chime in, not sure why your MAF are so low. Just crappy gas and high temps? Link to comment Share on other sites More sharing options...
black318i Posted August 11, 2009 Author Share Posted August 11, 2009 Yeah it was pretty hot out and I think the knock was a one time think, but I'm still going to keep an eye on that area. As far as gas I always use Shell. Mickeyd said I might me running too much boost above 5400 so I'm going to lower my target a few 10th and see what happens. Link to comment Share on other sites More sharing options...
black318i Posted August 12, 2009 Author Share Posted August 12, 2009 Another 3rd gear run lowered boost by .3 lbs from about 5.5k on.romraiderlog_20090811_164922.csv Link to comment Share on other sites More sharing options...
boostsr20 Posted August 12, 2009 Share Posted August 12, 2009 You need to smooth out your timing map from 5700-6000rpms. Other than that, it looks pretty solid. Link to comment Share on other sites More sharing options...
