teducci Posted July 28, 2009 Share Posted July 28, 2009 My 2008 2.5i legacy did not come equipped w/ fog lights. Has anyone installed any other fog lights (aftermarket fog lights) in the foglighs designated spot or anywhere else for that matter? Any pics would be appreciated. Link to comment Share on other sites More sharing options...
aldouse Posted July 29, 2009 Share Posted July 29, 2009 i have. sorry i failed to take pictures of them.. the fogs were just held in w/ double sided tape since i couldn't make up my mind on finalizing the install or not. needless to say.. a few hours driving later on dirt roads = cracked lenses on both fogs... that was the end of the aftermarket fogs. it works though... aiming the fogs was just a PITA. if i was to try and remount the fogs, i'd look into the license plate mounted ones. -- yay for the sig! -- my garage! Link to comment Share on other sites More sharing options...
CDN 2.5i Posted July 30, 2009 Share Posted July 30, 2009 I investigated a number of options but decided to just go with OE... everything is ready to just plug and play, wiring etc. If you want to save money, wait for a used set but don't forget you'll need the foglight turn signal stalk. If the OE lamps aren't bright enough, you can use a higher wattage H3 bulb such as an 80 watt or even 100 watt, but the latter may be risky for heat output. Alternatively, you can mount HIDs in the foglight housings as I and others have done... Link to comment Share on other sites More sharing options...
teducci Posted July 30, 2009 Author Share Posted July 30, 2009 where do you buy HID fog lights? If you have a link, I would appreciate it. Link to comment Share on other sites More sharing options...
CDN 2.5i Posted July 30, 2009 Share Posted July 30, 2009 H3 HID kit for the OE foglights... the OE foglights use an H3 bulb, so if you buy an HID kit for an H3 fitment, you can put them in the factory foglight housing Link to comment Share on other sites More sharing options...
09blkL3g Posted August 3, 2009 Share Posted August 3, 2009 H3 HID kit for the OE foglights... the OE foglights use an H3 bulb, so if you buy an HID kit for an H3 fitment, you can put them in the factory foglight housing I was thinking about doing this, but wondering if anyone can reccomend any projectors to replace the stock fogs Link to comment Share on other sites More sharing options...
CDN 2.5i Posted August 4, 2009 Share Posted August 4, 2009 The stock fogs are a projector lens afaik - there's a frosted globe inside the clear cover. Link to comment Share on other sites More sharing options...
katalyst Posted August 4, 2009 Share Posted August 4, 2009 you will still need the foglight covers though to mount them into the bumper even if you go aftermarket Link to comment Share on other sites More sharing options...
Whatisit Posted August 4, 2009 Share Posted August 4, 2009 The stock fogs are a projector lens afaik - there's a frosted globe inside the clear cover. 08+ arent projectors. and 08+ OEM fogs are really poorly designed. aftermarket is the way to go IMO. Link to comment Share on other sites More sharing options...
09blkL3g Posted August 4, 2009 Share Posted August 4, 2009 08+ arent projectors. and 08+ OEM fogs are really poorly designed. aftermarket is the way to go IMO. Yeap my 09 legacy OEM fogs are pointless. At night, with the headlights on, it makes no difference with the fogs on or off..I had to go look to make sure they even worked. So can anyone reccomend a good aftermarket projector? Link to comment Share on other sites More sharing options...
GraysonSubaru Posted September 19, 2009 Share Posted September 19, 2009 bump for this thread. I wish I could find a set of fogs like they offer on the WRX's...bigger JDM versions. I will likely do a different grille and do an install behind them as I did in my 2008 WRX, but would also like some more conventional located fogs. http://i241.photobucket.com/albums/ff286/chubert1/lights5.jpg http://i241.photobucket.com/albums/ff286/chubert1/lights4.jpg http://i241.photobucket.com/albums/ff286/chubert1/lights3.jpg http://i241.photobucket.com/albums/ff286/chubert1/IMG_9174.jpg Link to comment Share on other sites More sharing options...
09blkL3g Posted September 19, 2009 Share Posted September 19, 2009 Im going to end up going the dIY route and just mod some aftermarket projectors to fit the housing..post pics soon by the way nice car Grayson Link to comment Share on other sites More sharing options...
GraysonSubaru Posted September 20, 2009 Share Posted September 20, 2009 Thanks. that was the previous WRX. I am in a 2009 Legacy 3.0R now. Link to comment Share on other sites More sharing options...
