uniqsol Posted July 25, 2009 Share Posted July 25, 2009 I bought my 96 Legacy L wagon this past spring for my winter car. About a week ago I took a turn fairly fast (for a wagon) and the check engine light came on. I took it to Autozone and had them do a test that came back "Knock sensor". Thinking that maybe the sharp turn gave my sensor a bad reading I looked under the dash to see if there is reset button. I found a few wire harnesses that aren't connected to anything. Two green ones and a black one. Also, should I try to disconnect the battery for an hour and see if the light comes back on? Is there only one Knock Sensor on these cars? Is it difficult to replace? Thanks...Boxer noob. Link to comment Share on other sites More sharing options...
KnifeyMcShanker Posted July 26, 2009 Share Posted July 26, 2009 Those green and black wires put the car into diagnostic mode. They're supposed to be unconnected. The knock sensor is right underneath the intake manifold, if you have small hands you can get at it but for most it's easiest to take the manifold off to replace it. Make sure you put new gaskets on all the parts you take off, shouldn't be too hard of a job though. Link to comment Share on other sites More sharing options...
uniqsol Posted July 26, 2009 Author Share Posted July 26, 2009 I unhooked the battery for about 2 hours. The light is off now, but I havent driven it at all. Is it possible to get a false reading from cornering too hard? Link to comment Share on other sites More sharing options...
Platinum_Racing Posted July 26, 2009 Share Posted July 26, 2009 Check the wire connections if possible. A loose connector could cause this. For the most part if all is working as it should then taking turns too fast shouldn't matter. Also, unhooking the battery for a minute or two would do the exact same thing as 2 hours. A cars ECU consumes a little extra electricity to remember CEL codes than a clock radio that might remember time for a little while after it's unplugged. Good luck! Link to comment Share on other sites More sharing options...
ouch1011 Posted July 26, 2009 Share Posted July 26, 2009 Instead of waiting forever after disconnecting the battery, I've found that turning the key on and/or stepping on the brake pedal for about 30 seconds almost always works. The PCM has capacitors in it that can supply the KAM with enough power to retain its memory for several hours. Either turning on the key or hitting the brake pedal will discharge the capacitors very quickly. Link to comment Share on other sites More sharing options...
Bdubs Posted July 27, 2009 Share Posted July 27, 2009 A knock sensor CEL comes and goes. It really doesn't HURT driving the car with that code, but it's best to fix it so your engine will perform as it should. It's like a $30 part at a auto part store, and only involves one bolt to remove it. Something that easy you should just replace. Link to comment Share on other sites More sharing options...
