stlnet Posted July 19, 2009 Share Posted July 19, 2009 Well, when I'm out driving, the rear, left brake disk gets really hot, transfering heat to my rim and it smells burned rubber. I can touch the rim, without burning my hand, and there is no blue heat color (as far as I can see) on the brake disk, but I can clearly feel a difference from the right side of the car (the temperature one the right side rim is normal, and I don't feel that much heat from the brake disk). Any suggestions? How serious is this? Link to comment Share on other sites More sharing options...
Bolksey85 Posted July 19, 2009 Share Posted July 19, 2009 On a 10 year old car it could be a caliper hanging up on either side. Left is sticking when out and getting red hot or right side isn't going out and not working. It wouldn't be uncommon on an old Legacy. Fairly common I remember from my retail days. Link to comment Share on other sites More sharing options...
Verwilderd Posted July 19, 2009 Share Posted July 19, 2009 Check your pads as well to make sure they aren't warped, or mostly gone.. Link to comment Share on other sites More sharing options...
Deaks2 Posted July 20, 2009 Share Posted July 20, 2009 You may just need to lube up your slider pins. Link to comment Share on other sites More sharing options...
whitetiger Posted July 20, 2009 Share Posted July 20, 2009 sounds like one of the calipers or pads are stuck. Link to comment Share on other sites More sharing options...
