Max Capacity Posted July 19, 2009 Share Posted July 19, 2009 There are a couple of threads about this but I couldn't find one with pictures, so here's what I did. Here's the issue http://i185.photobucket.com/albums/x40/92Si/DSCN3628.jpg or this http://i185.photobucket.com/albums/x40/92Si/DSCN3641.jpg You need to remove the 2 screws http://i185.photobucket.com/albums/x40/92Si/DSCN3638.jpg http://i185.photobucket.com/albums/x40/92Si/DSCN3633.jpg Grab and pull http://i185.photobucket.com/albums/x40/92Si/DSCN3634.jpg The drivers side left me with this http://i185.photobucket.com/albums/x40/92Si/DSCN3635.jpg The passenger side came out all together. I used 2 thin screw drivers to pop the clips out http://i185.photobucket.com/albums/x40/92Si/DSCN3636.jpg Other pictures they may help http://i185.photobucket.com/albums/x40/92Si/DSCN3632.jpg This one shows the missing nylon insert I dropped if you look close you can see some of the square hole http://i185.photobucket.com/albums/x40/92Si/DSCN3639.jpg Here's one of the other threads http://legacygt.com/forums/showthread.php?t=93711 There's one more here some where just can't find now. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mikes_prescott Posted February 27, 2015 Share Posted February 27, 2015 Thank you for getting me a little closer to finding out the part # for this (whatever it is called!) 62280 is no longer a supported Part# at Subaru parts website. The ONLY thing I could find is 62282 - and that is for the inner molding piece. I need the exterior piece just like in the much appreciated pictures from this previous post. Subaru quoted me $191 and so I am pretty sure they are looking at something different. Looking for left rear EXTERIOR piece for a 2005 Legacy GT 2.5L automatic transmission - Wagon Link to comment Share on other sites More sharing options...
apexi Posted March 2, 2015 Share Posted March 2, 2015 It looks like 62280 should still be the correct number. Left Side - full subaru part number 62280AG011 http://parts.subaru.com/p/Subaru_2005_Legacy25L-TURBO-5AT-4WD25GT-LIMITEDOUTBACKXT-WAGON/WEATHER-STRIP-DOOR-REAR-OUTER-LEFT/49263335/62280AG011.html Right Side - full subaru part number 62280AG001 http://parts.subaru.com/p/Subaru_2005_Legacy25L-TURBO-5AT-4WD25GT-LIMITEDOUTBACKXT-WAGON/WEATHER-STRIP-DOOR-REAR-OUTER-RIGHT/49263332/62280AG001.html Link to comment Share on other sites More sharing options...
