Razor Posted July 17, 2009 Share Posted July 17, 2009 Hey guys, Is it safe to run just stock springs and no struts or anything? Will this reduce reliability and or longetivity? And how much can I drop my car with 18's ? Link to comment Share on other sites More sharing options...
j0ebert Posted July 17, 2009 Share Posted July 17, 2009 It's fine but your stock struts will start complaining pretty quick. Check alignment after. You can drop a lot with 18s...tire sidewall will play a factor. Link to comment Share on other sites More sharing options...
N.sane Posted July 17, 2009 Share Posted July 17, 2009 I've got aftermarket springs as my only suspension mod right now. Ride is a little more firm over bumps, but nothing the passengers would notice compared to stock. I would highly recommend changing struts at the same time though. Koni FTW Link to comment Share on other sites More sharing options...
Regal05LGT Posted July 17, 2009 Share Posted July 17, 2009 You can lower quite a bit with 18's just gotta watch the offset and tire size Should look into getting some struts too if you are looking to go low...stocks won't hold up too long prob. Link to comment Share on other sites More sharing options...
Razor Posted July 18, 2009 Author Share Posted July 18, 2009 Where is a good dealer that will do koni springs + struts. What am I looking at for a price here? and how many hours labour for install + alignment at a shop? Link to comment Share on other sites More sharing options...
N.sane Posted July 18, 2009 Share Posted July 18, 2009 Try using the dealer locator from Koni: http://www.koni-na.com/distributor.cfm Link to comment Share on other sites More sharing options...
