executor485 Posted July 7, 2009 Share Posted July 7, 2009 I'm not a wiring genius by any means, so I'm wondering if there is going to be a problem with this setup or not. I just got a JL 10w3 D6 (dual 6 ohm - didnt know it was a 6ohm :S) sub in today and I was planning on wiring it with my JL 10w3 D4. Is that going to be an issue because of the difference in OHMs? I had 2 10w3 d4's running in series/parallel previously, and I was planning on doing the same with this until I realized that its a 6ohm sub. Will there be any problems hooking it up in the same way, should I not run these subs together, or should I run it in parallel/parallel and be fine? Thanks If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
Town Posted July 7, 2009 Share Posted July 7, 2009 What amp? Link to comment Share on other sites More sharing options...
executor485 Posted July 7, 2009 Author Share Posted July 7, 2009 Jl 500/1 If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
biz77 Posted July 8, 2009 Share Posted July 8, 2009 First of all, you won't be able to execute a series/parallel scheme without four voice coils or a multiple of four voice coils. With one dual 6 ohm woofer you can either wire for a nominal 12 ohm load by wiring in series or a nominal 3 ohm load by wiring in parallel. A 3 ohm nominal load should be fine for your slash-series JL amp. Link to comment Share on other sites More sharing options...
